Have a ~1999 Torqcut 30 with low hours for its age. Dx32 Control, Parvex Servos on all 3 Axis.
My guys ran the mill a couple of days ago and ran fine. Upon start-up Friday morning we received a "Following Error" when we tried to home. Z-Axis and carousel homes fine then get the "Following Error" when it tries to home the Y-Axis. We can see the Following Error value by viewing the parameter in the MaintPage and the Y-Axis and Z-Axis are on the home limit switces and are indicated as such on the MaintPage. We can see the Y-Axis following error build in either direction as we turn the jog wheel up to 0.050 or down to -0.050 following error and then drives fault out.
Pulled the lower inspection plate to get a look at the Y-Axis motor and can see the motor pulley actually turn a small amount (though I think it is just compliance in the belt, torsion ect) either direction when we try to jog it then it springs back when the drives kick out. We cannot turn the motor pulley by hand with the drived de-energized. And we cannot push the table with brute force and backdrive the ball screw. At this point I'm thinking that somthing is mechanically blocking the Y-Axis travel.
It doesn't make sense though because it just happened while the machine was idle. This is a linear rail machine and everything looks pristine. No chips or oxidation on the linear rails or ball screw. Good coating of way oil on both as well.
Looking for any ideas from the more experienced out there. Anyone else have similar experience. Unfortunatley, the Y-Axis is all the way to the front of the machine and it looks as the only way to remove the Y-Motor is out the bottom an I have to remove the chip pan enclosure to do that. Bridgeport has made that look dificult. I looks like I have to remove the contol pod to be able to slide the enclosure forward.
I have a full set of manuals with the exception of the mechanical part drawings in the maintenance manual. Is there anybody that would be willing to share. I'm interested in knowing if I can can get access to ballscrew nut for the Y-Axis through the top so I can push the table to the back of the machine to see if that opens things up in the front of the machine. Diagrams or pictures would help. I think this is pretty much the same as a Torqcut 22 as well just longer X-Axis.
Thanks for any suggestions.
