586,100 active members*
2,810 visitors online*
Page 3 of 3 123
Results 41 to 48 of 48
  1. #41
    Dec 2011
    155
  2. #42
    Jun 2014
    Re: Dbsharp's Aluminum CNC
    Hello dbsharp,
    Thank you for sharing your design. Looks fantastic. I'm new to CNC design. Could you please share photos or just just explain how did you design your X (long) axis movement ? Did you use some kind of a rail or just use an aluminum as a surface ?
    Thank you in advance.
  3. #43
    Dec 2011
    155
    Ball screw in the center with thk linear rails on the underside of the bed.
  4. #44
    Jun 2014
    38
    Quote Originally Posted by dbsharp View Post
    dbsharp, you also said you used epoxy to hold the rails in place. I'm also trying to build a machine using tslot sections, and am concerned about the friction hold of the rails with tnuts in the sections. Though the flexibility to adjust individual t nuts to achieve parallelism is useful. Did you align your rails, and then pour the epoxy? Did you use any additives? Any details on this process will be greatly appreciated.
    Regards,
    Seshadri
  5. #45
    Dec 2011
    155
    Quote Originally Posted by Sesh View Post
    Regards,
    Seshadri
    I just poured it and tightened down the rails too the epoxy bed. Its a "precision" leveling epoxy and as far as I can tell it lays down pretty flat if its is tick enough. I have indicated off of a large precision square and the axis seems to run straight to ±.001". Considering its a weldment that got no stress relieving thats not too bad.
  6. #46
    Dec 2011
    155
    I have uploaded models to Grabcad for this machine. Good luck to anyone who wants to make one. I also posted my 4th axis. https://grabcad.com/library/sharp-s-cnc-asy-1
  7. #47
    Dec 2011
    155
    I have occasional issues with this machine on rapids where the motors just dont want to keep up. Being closed loop steppers, they get there but you can tell they lose position. I have done some analysis and will share this. The automationtechnologies (leadshine) closed loop steppers seem to get bogged down from the drag in the ball nut when they are dirty. Even with this they are light years better than the steppes I used to run.
    I have decided to gear them down, and I have charted the force and speed with the gear reduction, and this seems like a no brainer now that I can see the data.
Name:	Belt drive.jpg
    I also measured current draw on my machine to determine the power supply needed for my Lathe project https://www.cnczone.com/forums/verti...6-cnc-cad.html.
    Max sustained amps were measured at motor speeds of 750-1000 rpm with me pushing hard enough against the machine to make the motors have some positional error. This is where this drive kicks on higher holding torque to catch back up. I'm 6ft3in and 300 lbs and this was actually pretty hard to do on the bigger motor.
    KL-8082H with KL-34-8N-1000 at 72V: Max sustained 4.2 amps with around 1-2 under normal circumstances
    KL-5080H with KL-23-2N-1000 at 40V: Max sustained 2.2 amps with around .5-1 under normal circumstances
  8. #48
    Apr 2007
    8082
    Glad that you got that issue sorted out.
    I'm still using the heck out of my standard step motors, but haven't had any problems with them so far. Have to keep the mechanics lightly lubed and clean off any dust and debris. All of my work since building the last two machines in this forum is shown on the Vectric Aspire or Vcarve Pro forums.
    Carry on sir, the rifle stocks look superb.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
Page 3 of 3 123
  1. Aluminum Extrusions, Steel, or Aluminum Tubing which one for CNC frame?
    By dinkyguitar in forum DIY CNC Router Table Machines
    Last Post: 06-14-2012, 02:51 AM
  2. Should I use MIC 6 Aluminum or Regular Plate Aluminum
    By newpatch in forum DIY CNC Router Table Machines
    Last Post: 03-20-2012, 07:49 PM
  3. 80/20 aluminum gantry, milled aluminum ends
    By 3Dsigns in forum DIY CNC Router Table Machines
    Last Post: 10-15-2010, 09:55 PM
  4. Carbide endmills Aluminum vs non-aluminum ???
    By zaebis in forum MetalWork Discussion
    Last Post: 09-14-2009, 02:53 PM
  5. pressing aluminum into an aluminum tube
    By Fishin_Rod in forum Mechanical Calculations/Engineering Design
    Last Post: 07-01-2009, 06:23 AM
