I just finished refurbishing a Varnamo (NOS) Swedish CNC knee mill. The original 5.5 hp spindle and horizontal motors were still mounted but the tape drive computer, servos etc had all been removed. I replaced these with all Ajax CNC servos and controller/encoders which runs on Linux. I set up the computer so that it runs as a regular PC so I can use BOBCCAM 20 and BOBART ProX with a scanner, then push in the drive and the computer becomes a Linux system for the G code. The combined Ajax Linux/PC BobCAD system works beautifully. Now I am building a CNC Pasma/Router combo on a 5x10 frame. I plan to use 80/20 components for the frame since I will eventually have to move the table and it will be easier to break down than moving a one piece welded one. I also like the ability to modify the design as I go along and the 80/20 seems to offer a lot of flexibilty to change the design during the build.
I do like the accuracy of servos and the abilty in the Ajax contollers to start, stop and modify any line of g code during the cut. If I stayed with the AJAX controller, is there a torch height controller that would work with this system? Most of the torch height controllers I've seen only work on Mach 2 software and utilize the PC as the controller. I was wondering about the accuracy of a dedicated controller vs pc as the controller, servos vs steppers, and using ballscrews on Y and Z axis vs rack and pinion. What would give the greatest accuracy on a 10 ft X axis? If you were to build your ultimate CNC Plasma/Router, what components would you use if cost wasn't an issue? Thanks!
