586,121 active members*
3,755 visitors online*
    Jul 2012
    NPTF Threads help please !
    Ok I have a new job and the machines are Mazak but ...... They are not so new ! They just bought them maybe in 1958 !!!! They are on the T 32 format . The one is giving MASS headaches with just about EVERYTHING . I am attempting to put a 3/8-18 NPTF thread on the back of the part . The O.A.L. is .900 from the face of the part to the end of the thread is ..463 with the typical 1.783 degrees of angle . And has a .5 ( dia . of thread relief by .098 wide ) thread relief . I have tried writing it from the O.A.L. back to the .577 but could not get the angle to come out for the trunc. gauge to work . So I went back to the idea of starting from the end of the thread( .463 ) and tapering down the to end of the part . Now I am getting reverse contour errors , illeagle start cut point errors .
    I even fallowed an old program TO THE LETTER AND NUMBER and for something completely different the previous guy wrote ( as I said I am new to the shop ) Just to see if it would even run the trace . It went a head and mapped out the outline of that part but when running the tool path it freaked out and gave me an error because it read the edgfce movement .
    Any ideas on what to try next ? Even maybe put up a process for me to try ?
    Thanks Billy
    Nov 2009
    82
    can you post the part print and what you are exactly trying to accomplish? Mazatrol is good but not as versatile as G-code.
    May 2012
    Uhh....there were no T-32s back in 1958. It would have to have a few thousand vacuum tubes if it was.
    Jan 2012
    Are you thread milling???
    May 2004
    4519
    I took it that this is a lathe part. If he has EIA, he could just G-code it.
  1. programing a 1" NPTF ID thread
    By 69ss396 in forum Haas Lathes
    Last Post: 11-27-2008, 07:06 AM
  2. NC vs NF threads
    By bobchiloquin in forum Mechanical Calculations/Engineering Design
    Last Post: 05-06-2008, 12:53 AM
  3. SFM for NPTF in class 30 grey iron?
    By MrUZU1 in forum MetalWork Discussion
    Last Post: 06-01-2007, 04:41 AM
  4. npt threads
    By brtlatjgt in forum Uncategorised MetalWorking Machines
    Last Post: 10-24-2003, 04:42 AM
