586,058 active members*
4,281 visitors online*
IndustryArena Forum > CAM Software > Vectric > Cut 2D Profile pass
    Jun 2012
    23
    Cut 2D Profile pass
    Hi Guys, I have a 12.5mm (1/2") piece of rough sawn plate I wish to trim to size around the perimeter before continuing on with other operations on it. The cut is app 2mm wide by full depth. I would like the cutter to cut full depth with 2 passes of 1mm DOC (Side ways)
    In Cut 2d if I set this to an out side profile cut, it brings the cutter down so it plunges first into the part and then moves around the perimiter. Is there any way to set some sort of lead in so it doesn't have to PLUNGE down through the entire thickness off the part. So to sumarise I want the cutter to cut from the side, not plunge cut first. (I have done a poor job of explaining that):drowning:
    Hope you get what I mean. anf thanks in advance for the help.
    Regards, Warren.
    is it a rectangle, just draw with lead in and bigger than your finished size by half cutter size and cut ON the line
    Jun 2012
    23
    CLEVER... CLEVER.. I knew you guys would have figurded a way around it, thanks heaps..:cheers:
  1. Pass Through?
    By Jtron5 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-09-2011, 09:45 PM
  2. Bad pass
    By ozstockman in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 01-04-2010, 08:32 AM
  3. G71 rough boring - remove final profile pass
    By Busted in forum G-Code Programing
    Last Post: 01-19-2009, 07:08 PM
  4. cut depth per pass
    By christ371 in forum Dolphin CAD/CAM
    Last Post: 07-20-2008, 03:14 AM
  5. Heidenhain pass
    By inioxos in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-09-2007, 07:00 PM
