586,117 active members*
3,364 visitors online*
IndustryArena Forum > CAM Software > Esprit > ESPRIT 2012 POST Question
Results 1 to 10 of 10
    Feb 2012
    Daewoo / Doosan ACE 500
    Fanuc 18-M Control
    Haas Rotary 4th axis
    Good afternoon,
    I am fairly new to esprit, and I am curious if there is a way to edit the post processors for 3D arcs instead of line-by-line stlye of programming. Any thoughts would be greatly appreciated.
    regards,
    J
    Jun 2010
    81
    The output changes depending on how you program the part or how you describe the cut. Could you post an example or be more specific?
    Jan 2012
    59
    are you talking about G17 and G18 arcs nurbs and splines ?
    its in machine setup Optimize toolpath
    Aug 2008
    23
    Hello friends,
    This is a problem for Esprit users.
    I have a multitask machine CTX Beta 1250 with sinumerik 840D.
    I have set up in the work coordinate NONE and in the machine config at 5 axis tab i have Rotate With Part.
    I have also used work turning coordinates.
    Please check this movie and tell me what i can do to fix the problem : http://www.youtube.com/watch?v=QvwcCB5HF-U
    Thanks a lot !
    Nick
    Jan 2012
    59
    looks like you are doing wrap contouring in esprit but its not posting right.
    try turnig off rotate with part. I'm just guessing we use mazaks and also have post problems with esprit
    Aug 2008
    23
    I have tried also with FIXED but is not working at all. At least with Rotate with Part it goes there at the pocket, is folowing the contour but is not doing same like in the simulation.
    So, if somebody has a PP for CTX Beta 1250 TC with sinumerik 840Dsl i can give back also a lot of PP and machine configurations and files...etc
    BTW, do u have MAzak Integrex IV with Matrix control ?
    Have a nice evening !
    Nick
    Aug 2008
    23
    There is anybody who have a 5 axis program for CTX Beta 1250TC ? I just need it for preparing a PP - sample. Controller is Sinunerik 840D
    Thanks a lot !
    Aug 2008
    23
    As i understood in the machine setup i should have FIXED. There is not support for TRAORI. Can somebody help me with a 5 axis program ? Maybe my friend can write a new POST !
    Thanks a lot !
    May 2013
    Feb 2011
    252
    You need a postprocessor for Esprit cam - [email protected]
    I have a postprocessor for all machines ..
  1. esprit 2012
    By thehorton in forum Esprit
    Last Post: 08-30-2012, 07:15 PM
  2. 2012 International Conference on Mechatronics and Computational Mechanics(ICMCM 2012)
    By gaotie in forum Trade Shows / Webinars / Other Events
    Last Post: 06-25-2012, 02:29 AM
  3. NEED FANUC POST FOR ESPRIT 2012
    By thesePAPERwalls in forum Esprit
    Last Post: 05-24-2012, 06:17 PM
  4. NEED HELP WITH ESPRIT 2012
    Last Post: 05-22-2012, 04:38 PM
