586,116 active members*
3,251 visitors online*
Results 1 to 13 of 13
    Mar 2005
    305
    Need Star in .dxf
    Any one have a good symetrical star in .dxf? I drew what I thought was correct multiple times. No luck.
    Any help would be appreciated.
    Oct 2003
    593
    What size and how many points would you like.
    Here's a real quick one I did.
    Regards Terry.
    Attached Files Attached Files
    Mar 2005
    305
    That will work quite fine. Thank you.
    Now, how do you draw a good star.
    Oct 2003
    593
    Well that one took about 3 seconds in Rhino.
    I just chose (Polygon > Star > 5 points.)
    Not much help unless your CAD has that feature.
    Regards Terry.
    Oct 2004
    727
    Here's another 5 pointer (this one hasn't been gutted)
    Too quick for me Mr. Bean. I'll post mine anyway since my 5 pointer hasn't been gutted.
    Here's a link to the geometry involved in regular pentagons & 5 pointed stars:
    The Regular Pentagon (with 5 pointed star).
    "When you wish upon a star" you may wind up with more than one!
    HayTay
    How about this one?
    Mar 2005
    305
    Somehow that one does not look like the Texas Ranger star/badge I am laying out for a guy. Cool none the less.
    Jun 2003
    2103
    rcazwillis,
    Just a word of caution. If you are replicating a Ranger badge you might want to check on the legalities. I had a friend (now dead) that was a big
    E-bayer, and happened on a real Ranger badge at a gun show or flea market. He put it on E-bay and two days later he has a visitor at his door. It wasn't UPS either!
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Mar 2005
    305
    Mike,
    Thanks for the word of caution. We are not actually replicating the badge. Just the shape, no words, in a sissy bar insert for a motor cycle. The guy is law enforcement and likes old badge styles. A JPG is attached.
    Oct 2005
    1238
    Is that a "SpiroStar" from your spirograph?
    Looks neat!
    Yes, from the AutoCAD macro i threw together.
    Jun 2004
    487
    Wow Mr Bean, I never knew I had that feature in Rhino. Doh!
    Here's how I used to do it (the hard way):
    1. Decide the height of the star
    2. Plot first point (pline) at 0,0
    3. Second point is X=1/3 of height, Y=height
    4. Third point is X=2/3 height, Y=0
    5. Make a copy of this triangle
    6. Rotate the figure:
    Rhino: select the 1st point as rotation center, 3rd point as 1st reference and 2nd point as 2nd reference.
    AutoCAD: select 1st point as base and 2nd point as reference.
    The second leg of the triangle should be horizontal now.
    7. Move the rotated figure from 1st point (0,0) and snap it to the other figure's 3rd point
    8. Draw a line from the moved figure 3rd point to the other figure's 1st point.
    9. Select all, trim centers and join, if desired
    JR
    Oct 2003
    593
    He he he. The polygon (star), tool in Rhino should cut down on time compared to your old method.
    I seem to find new features in Rhino every time I use it.
