586,770 active members*
8,917 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > problems loading to Tree 325 with Delta 20 control
Results 1 to 8 of 8
    Jul 2004
    176
    Hopefully this will be the last need help for awhile thread.
    I have the Dynapath Delta 20 control.
    Using gibbscam and its built in communications,.
    Running a laptop and using the cable that came with the machine that was used successfully before. db9 to db25
    I keep getting a load error. Trying to figure if it in in my settings, the program or the laptop. Any suggestions would be appreciated.
    On the machine the settings are
    Buad rate of 1200
    PO is highlighted- parity off
    X0 is highlighted-chr off
    E0 is highlited.- echo off
    In Gibbscam in my comm preferences
    Baud- 1200
    Parity- none
    Data-7
    Stop-1
    Handshake- xon/xoff
    port-com1
    end of block- LF
    sample of program
    (1234)$
    N2(T)TOOL 1$
    N4(T)OPERATION 1$
    N6(9)T0001M6E1$
    N8(9)M9$
    N10(9)M3S3500$
    N12(0)X0.3344Y0.918$
    N14(0)Z0$
    N16(0)Z0.1$
    N18(1)Z-0.0575F100.0$
    N20(2)X0.8505Y0.4346I0.8341J0.9343D1$
    N22(2)X0.187Y-0.6136I0.875J-0.315D0$
    N24(1)Y-0.0164$
    N26(2)X0.8505Y0.4346I0.875J-0.315D0$
    N28(2)X1.3338Y0.9507I0.8341J0.9343D1$
    N30(0)Z0.1$
    N32(0)X0.3344Y0.918$
    N34(0)Z0.0425$
    N36(1)Z-0.115$
    N38(2)X0.8505Y0.4346I0.8341J0.9343D1$
    N40(2)X0.187Y-0.6136I0.875J-0.315D0$
    N42(1)Y-0.0164$
    N44(2)X0.8505Y0.4346I0.875J-0.315D0$
    N46(2)X1.3338Y0.9507I0.8341J0.9343D1$
    N48(0)Z0.1$
    N50(0)X0.3344Y0.918$
    N52(0)Z-0.015$
    N54(1)Z-0.1725$
    N56(2)X0.8505Y0.4346I0.8341J0.9343D1$
    N58(2)X0.187Y-0.6136I0.875J-0.315D0$
    N60(1)Y-0.0164$
    N62(2)X0.8505Y0.4346I0.875J-0.315D0$
    N64(2)X1.3338Y0.9507I0.8341J0.9343D1$
    N66(0)Z0.1$
    N68(0)X0.3344Y0.918$
    N70(0)Z-0.0725$
    N72(1)Z-0.23$
    N74(2)X0.8505Y0.4346I0.8341J0.9343D1$
    N76(2)X0.187Y-0.6136I0.875J-0.315D0$
    N78(1)Y-0.0164$
    N80(2)X0.8505Y0.4346I0.875J-0.315D0$
    N82(2)X1.3338Y0.9507I0.8341J0.9343D1$
    N84(0)Z0.1$
    N86(0)X0.3344Y0.918$
    N88(0)Z-0.13$
    N90(1)Z-0.2875$
    N92(2)X0.8505Y0.4346I0.8341J0.9343D1$
    N94(2)X0.187Y-0.6136I0.875J-0.315D0$
    N96(1)Y-0.0164$
    N98(2)X0.8505Y0.4346I0.875J-0.315D0$
    N100(2)X1.3338Y0.9507I0.8341J0.9343D1$
    N102(0)Z0.1$
    N104(0)X0.3344Y0.918$
    N106(0)Z-0.1875$
    N108(1)Z-0.345$
    N110(2)X0.8505Y0.4346I0.8341J0.9343D1$
    N112(2)X0.187Y-0.6136I0.875J-0.315D0$
    N114(1)Y-0.0164$
    N116(2)X0.8505Y0.4346I0.875J-0.315D0$
    N118(2)X1.3338Y0.9507I0.8341J0.9343D1$
    N120(0)Z0.1$
    N122(0)X0.3344Y0.918$
    N124(0)Z-0.245$
    N126(1)Z-0.4025$
    N128(2)X0.8505Y0.4346I0.8341J0.9343D1$
    N130(2)X0.187Y-0.6136I0.875J-0.315D0$
    N132(1)Y-0.0164$
    N134(2)X0.8505Y0.4346I0.875J-0.315D0$
    N136(2)X1.3338Y0.9507I0.8341J0.9343D1$
    N138(0)Z0.1$
    N140(0)X0.3344Y0.918$
    N142(0)Z-0.3025$
    N144(1)Z-0.46$
    N146(2)X0.8505Y0.4346I0.8341J0.9343D1$
    N148(2)X0.187Y-0.6136I0.875J-0.315D0$
    N150(1)Y-0.0164$
    N152(2)X0.8505Y0.4346I0.875J-0.315D0$
    N154(2)X1.3338Y0.9507I0.8341J0.9343D1$
    N156(0)Z0.1$
    N158(0)X0.3344Y0.918$
    N160(0)Z-0.36$
    N162(1)Z-0.5175$
    N164(2)X0.8505Y0.4346I0.8341J0.9343D1$
    N166(2)X0.187Y-0.6136I0.875J-0.315D0$
    N168(1)Y-0.0164$
    N170(2)X0.8505Y0.4346I0.875J-0.315D0$
    N172(2)X1.3338Y0.9507I0.8341J0.9343D1$
    N174(0)Z0.1$
    N176(0)X0.3344Y0.918$
    N178(0)Z-0.4175$
    N180(1)Z-0.575$
    N182(2)X0.8505Y0.4346I0.8341J0.9343D1$
    N184(2)X0.187Y-0.6136I0.875J-0.315D0$
    N186(1)Y-0.0164$
    N188(2)X0.8505Y0.4346I0.875J-0.315D0$
    N190(2)X1.3338Y0.9507I0.8341J0.9343D1$
    N192(0)Z0.1$
    N194(0)X0.3344Y0.918$
    N196(0)Z-0.475$
    N198(1)Z-0.6325$
    N200(2)X0.8505Y0.4346I0.8341J0.9343D1$
    N202(2)X0.187Y-0.6136I0.875J-0.315D0$
    N204(1)Y-0.0164$
    N206(2)X0.8505Y0.4346I0.875J-0.315D0$
    N208(2)X1.3338Y0.9507I0.8341J0.9343D1$
    N210(0)Z0.1$
    N212(0)X0.3344Y0.918$
    N214(0)Z-0.5325$
    N216(1)Z-0.69$
    N218(2)X0.8505Y0.4346I0.8341J0.9343D1$
    N220(2)X0.187Y-0.6136I0.875J-0.315D0$
    N222(1)Y-0.0164$
    N224(2)X0.8505Y0.4346I0.875J-0.315D0$
    N226(2)X1.3338Y0.9507I0.8341J0.9343D1$
    N228(0)Z0.1$
    N230(T)TOOL 1$
    N232(T)OPERATION 2$
    N234(0)X0.3676Y0.927$
    N236(1)Z-0.69$
    N238(2)X0.8706Y0.43I0.8676J0.93F50.0D1$
    N240(2)X0.192Y-0.6126I0.875J-0.315D0$
    N242(1)Y-0.0174$
    N244(2)X0.8706Y0.43I0.875J-0.315D0$
    N246(2)X1.3676Y0.9329I0.8676J0.93D1$
    N248(0)Z0.1$
    N250(9)M30$
    END$
    edit- have taken out the $ at the begining and made the end just an E
    Oct 2009
    27
    Don't Put "$" after program name (1234) and just use a "E" inplace of "END$" to end your program. You also can not have any program numbers in front of either the program name or the E at the end of your programs. Hope this helps.
    Jul 2004
    176
    tried that earlier and didnt work unfortunately.
    Oct 2009
    27
    On my machine I have to have T01,M06, E01 ect. T1, M6, E1, always gives me a error. I never tried T0001 like you have, which maybe OK, but I have heard other people claim you have to have 2 digits for T,M,E functions, good luck
    Jul 2004
    176
    Thanks, I will try that.
    Would you have a small file that you know loads, that you would be willing to send to me to try?
    Would appreciate it.
    Oct 2009
    27
    I only program in reg. G-code (EIA) so I'm not sure this will help much, but I've run this little program many times. All my programs are stored on a computer and downloaded every time I need to run them, so it has been loaded successfully many times.
    (1)
    N2 G17
    N3 G40
    N4 G70
    N5 G80
    N6 G90
    N7 G94
    N8 (T)T01-centerdrill,T02-7/16 DRILL$
    N9 (T)00BACKLEFT,TUBEHOLE BACKRIGHT$
    N10 (T)Z0 TOP OF STEP, STEP TO FRT length 4.480$
    N11 T01M06
    N12 S900M03
    N13 M08
    N14 (T)OFFSET 1 IS PART ZERO$
    N15 E01
    N16 G00X1.105Y-2.312Z.02
    N17 G81X1.105Y-2.312Z-.15R.02F1.0
    N18 X2.105Y-2.687
    N19 X2.855Y-2.312
    N20 X3.855Y-2.687
    N21 G80
    N22 T02M06
    N23 S400M03
    N24 M08
    N25 E01
    N26 G00X1.105Y-2.312Z.02
    N27 G73X1.105Y-2.312Z-.825R.025K.08Q.015F1.0
    N28 X2.105Y-2.687
    N29 X2.855Y-2.312
    N30 X3.855Y-2.687
    N31 G80
    N32 M30
    E
    Oct 2009
    27
    Looking at your original program, on line N14 you have no decimal point, just Z0$, 99% sure you need it to be, Z0.$ or Z.0$ or Z0.0$ It's easy to miss those pesky little devils!
    Jul 2004
    176
    Will try these aswell when I get a chance between production jobs.
  1. problems loading to Tree 325 with Delta 20 control
    By cnctoolman in forum Dynapath
    Last Post: 08-04-2012, 12:51 AM
  2. how to tap with a delta 20 tree 310
    By garychipmaker in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-14-2011, 11:19 PM
  3. Tree VMC 840 with Dynapath Delta control
    By Shane1234 in forum Tree
    Last Post: 07-26-2011, 12:47 AM
  4. Tree VMC-840 with delta 20M
    By bob1112 in forum Tree
    Last Post: 11-29-2010, 04:20 AM
  5. problem finish loading program to delta 20
    By dingo0722 in forum Uncategorised MetalWorking Machines
    Last Post: 06-09-2010, 01:47 AM
