I could use some help.
The coolant pump stopped on my 1995 K-15.
When I manually press the button on the MS3 solenoid,
the pump runs and coolant flows.
What do I check next?
Thanks in advance.
Thanks in advance.
did you check the relais?
No. The book says it's RY8 but I don't know what it looks like or where it is.
Ok but what Hyundai-kia machine model is a K 5....
and which controler does it has
Model KT 15
Serial #KT15306
Yasnac LX3
Solved.
Turned out to be the MS3 coolant solenoid.
