Now i know the tm2 is not the strogest of machines but my machine has an annoying vibration when taking an X plus cut, imagine a 100mm sqaure and start machining at the top right side, y- direction then x- then y+ all is fine but when it goes x+ the machine vibrates a lot more,
the part is aluminium using ally carbide slot drill that i know work great, z depth of cut is -15mm with a radial cut of only 1.5mm, rpm 4000 and a feed of 400mm/min, any ideas.
