Lost battery power and am now trying to set parameters from japanese back to english. I know its 1043 i just dont know how to get there and change it since everything is still in japanese any help would be great
Hi
If you did not come right yet I can help you - send the procedure or via Skype - contact me.
Peter
the positions of the menu items are still at the same place regardless of the language. you could use an english manual and refer to a diagram of the menu items and just blindly press the buttons at the same physical location to get you to where you need to be.
or if your RS232 port is set up and working you could cheat....
press hardkey DIAGN IN/OUT
press softkey MENU (5th menu button from left) to display the next menu items.
press DATA OUTPUT (2nd menu button from left)
# (3) then INPUT/CALC (3 is 'parameter')
this will output all parameters to a file on your PC linked via RS232 cable.
On the PC manually edit the parameter file, parameter number 1043. set it to 1 for English language and save the file.
then input the parameters....
DATA INPUT (1st menu button from left)
when the input is complete turn power off/on and your machine should be in English.
Hi guys, in the company where I work we have a Mori Seiki TV30 with Meldas 50M, which is presenting the following alarms:
z70 0001 abs illegal xyz2
y03 amp unequipped 2s
emg emergency plc
m01 Operation Error 0101
also spindle drive will not turn even though the supply voltage reaches him. And being in a state of emergency, no axis moves. I would appreciate any help you can give me
