Hello everyone,
i have a S01 SERVO ALARM:PR 0071 with MITSUBISHI MDS-B-SP-185 (spindle) and MDS-A-V1-45 and MDS-A-V2-3535 for axes.
It just appears after some time working (sometimes over an hour or more of work) and machine stops because of that.
I can't figure out pattern that triggers that alarm...Alarm manual says that 0071 alarm means INSTANTANEOUS POWER INTERRUPTION.
Machine monitor also displays STAR-DELTA SWITCHING PROBLEM under S01 ALARM but i don't think that's a problem because spindle rotates at 6000 RPM (program set) all the way, so STAR-DELTA switching occurs only at power up and power down.
Pieces which are manufactured are aluminum cubes with gentle cycles so any harsh movement and overloading of driver isn't the case.
Also i'm not sure for what that alarm stands for...i found it under axes alarm, so that would indicate axes servo driving error but machine monitor also displays SPINDLE AMPLIFIER ALARM (i guess because of STAR-DELTA).
Just to mention, DC link is about 280V at 6000RPM without load so that's OK i guess, but i didn't measure PSU DC with load, that's my next step.
Here it is, if anyone can comment a bit this issue it will be greatly appreciated, thanks guys!
