586,058 active members*
3,889 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > program for star swiss type lathe
    Jul 2007
    82
    Smile program for star swiss type lathe
    Hello,
    Could you guys post some sample program for star swiss type lathe, please (Fanuc control). I was programming TW-10, WT-150 Nakamura Tome and Maier 20MLD swiss. Now I'm trying to learn something new and basically I need some starting point. Thank you.
    Nov 2009
    12
    Star sample Headings
    (TOP HEADING FOR HEAD 1)
    O0006(PART NUMBER GOES HERE)
    (PART NAME GOES HERE)
    (HEAD 1)
    M150 (ROTARY MAGIC BUSHING ON)
    G99G97G0G40M9
    #531=.75(***CHANGE TO STOCK SIZE***)
    M3S300
    IF[#5041GT0]GOTO1000
    M11 (OPEN MAIN COLLET)
    G4U.5
    G0Z.535T0
    M10 (CLOSE MAIN COLLET)
    G4U.5 (G4 IS DWELL, U IS TIMED FOR 1/2 SECOND)
    G120Z.535 (Z-AXIS COORDINATE SYSTEM SETTING)
    M5 (STOP MAIN SPINDLE)
    M200 (WAIT CODE)
    M20 (ONE CYCLE STOP)
    M10
    T100 (TOOL NUMBER)
    G0X1.5Z-.05
    /M25 (COOLANT ON)
    M27(BROKEN CUTOFF DET.)
    (MAIN BODY OF PROGRAM STARTS HERE)
    (CUT OFF)
    M25
    T100
    G99G97
    M3S2000
    Z1.556T1
    G0X[#531+.05]
    M82
    M40
    G1U-.1F.0015
    G0U.1
    W.025
    G1X[#531] F.008
    U-.05W-.025
    X-.03
    M41
    G0W-.05
    M83
    M80
    /M98P7000
    M99
    (BOTTOM HEADING FOR HEAD 1)
    N1000
    M10
    G4U.5
    G28U0 (RAPID HOME, U IS 'X')
    M25
    T200
    T100
    G99G97G40M9 (G99=FEED PER REVOLUTION, G97=CONSTANT SURFACE OFF)
    (G40=TOOL NOSE RADIUS COMP. OFF, M9=MAIN 'C' AXIS OFF)
    M3S1200 (MAIN SPINDLE CLOCKWISE @ 1200 RPM)
    G0X[#531+.05]W.02
    G1U-.1F.001
    G0X[#531+.05]
    W.02
    G1X#531F.001
    G1U-.04W-.02F.001
    G1X-.03F.0015
    M11 (MAIN COLLET OPEN)
    G4U.5
    M5
    G28W0T0
    G0W8.75 (10.63-PART LENGTH-CUTOFF BLADE WIDTH-FACE AMOUNT-~.25)
    G120Z0. (Z-AXIS COORDINATE SYSTEM SETTING)
    M10
    M99
    (HEAD 2 SAMPLE)
    O0006(5152938)
    (SCREW, BREECH LOCK CAM)
    (HEAD 2)
    G99G97G0G40M5
    G130(Z AXIS ZERO HOME)
    G28W0T0(MOVES TO HOME POS)
    G50Z0(SETS Z 0)
    T2000(MOVES TO X ZERO)
    M200(WAITS ON HEAD 1)
    M20(ONE CYCLE STOP)
    M25(C00LANT ON)
    M75(OPITIONAL BLOCK SK ON)
    M300 (WAIT CODE)
    /M5(SPINDLE STOP)
    /M8 (SUB C-AXIS ON)
    /G0C90.
    /G0Z-.05T16
    M310 (WAIT CODE)
    /G98
    /G1Z.062F2.
    M320(WAIT CODE USED AS NEEDED TO MATCH HEAD 1)
    M330(WAIT CODE)
    M340(WAIT CODE)
    /G1Z-.05F2.
    /G0Z0T0
    /M9
    M350
    (EJECTION OF PART)
    /T2900
    /M3S300
    /G0W1.5
    /M14(AIR BLOW ON)
    /M11(OPEN COLLET)
    /G4U.5(DWELLS 1/2 SEC.)
    /M15(AIR BLOW OFF)
    /M27(PART EJECTION ERROR)
    /G0Z0T0(Z AXIS HOME)
    /M5(SPINDLE STOP)
    /T2000(X AXIS HOME)
    /M84 (PARTS CONVEYOR ON)
    M76(OPITIONAL BLOCK SKIP OFF)
    M01
    (PART PICKUP)
    M4S3000
    M11(COLLET OPEN)
    M82(SPINDLE SYNC ON,WAIT)
    G131(ZERO ON FACE PART REF)
    G0Z-.250
    M68(FEED TORQ ON)
    G98(FEED-INCH/MIN)
    G1Z.600F100.
    G99(FEED INCH/REV)
    G130(ZERO,Z AXIS HOME REF)
    M10(CLOSE COLLET)
    M69(FEED TORQ OFF)
    M40(Z1 & Z2 AXIS LOCK ON,WAIT)
    M41(Z1 & Z2 AXIS LOCK OFF,WAIT)
    G98(FEED INCH/MIN)
    M68(FEED TORQ ON)
    G1W-.25F100.
    M69(FEED TORQ OFF)
    M83(SPINDLE LOCK OFF,WAIT)
    G0Z0T0(Z AXIS HOME)
    M5(SPINDLE OFF)
    M26(COOLANT OFF)
    M99(REWIND TO TOP)
    (ACTUAL PROGRAM HEAD 1)
    O2642(CUSTOMER NAME)
    (PART NAME)
    (PART NUMBER)
    (DATE RAN: 04/04/2012)
    (HEAD 1)
    M150
    G99G97G0G40M9
    #531=.993
    M3S300
    M11
    G4U2.
    G0Z.56T0
    M10
    G4U2.
    G120Z.56
    M5
    M200
    M20
    M10
    T100
    G0X1.5Z-.05
    /M25
    M27
    (FACE)
    M25
    T200
    G50S3000
    G99G96
    M3S300
    G0Z-.05T2
    X1.1Z.02
    G1X.993
    X.953Z0F.002
    X-.032
    G0Z-.05
    X2.0
    T0
    M5
    M1
    (.375 DIA. SPOT DRILL)
    M25
    T1100
    G50S4000
    G99G97
    M3S1500
    G0Z-.05T11
    X0.0
    G1Z.075F.002
    G4U1.
    G0Z-.05
    T0
    M5
    M1
    (.272 DIA. DRILL)
    M25
    T1200
    G99G97
    M3S650
    G0Z-.05T12
    X0.0
    G83Z.822R.05Q0500F.004
    G80
    G0Z-.05
    T0
    M5
    M1
    (TURN OD)
    M25
    T200
    G50S1700
    G99G96
    M3S350
    G0Z-.05T2
    X.490
    G1Z0F.005
    X.5
    G2X.6Z.05R.05
    G1Z.622
    X.8455
    G2X.938Z.6683R.0462
    G1Z.822
    X1.0794Z.7513
    G0X2.
    T0
    M1
    (CUT OFF)
    M25
    T100
    G99G97
    M3S810
    G0X1.025Z1.358T1
    M82
    M40
    G1X.94F.0015
    G0X1.04
    W.025
    G1X.99
    G1U-.0W-.025
    G1X-.035
    M41
    M83
    M80
    /M98P7000
    M99
    N1000
    M10
    M150
    G4U2.
    G28U0
    T0
    M25
    T200
    T100
    G99G97G40M9
    M3S810T1
    G0X[#531+.05]W.02
    G1U-.1F.0008
    G0X[#531+.05]
    W.02
    G1X#531F.0008
    G1U-.04W-.02F.0008
    G1X-.03F.0008
    M11
    G4U2.
    M5
    G28W0T0
    G0W9.028
    G120Z.0
    M10
    M99
    (ACTUAL PROGRAM HEAD 2)
    O2642(PROGRAM NUMBER)
    (CUSTOMER)
    (PART NAME)
    (PART NUMBER)
    (HEAD 2)
    G99G97G0G40M5
    M9
    G130(Z AXIS COORD. SYS. OFF)
    G50Z0(SETS Z 0)
    M20(ONE CYCLE STOP)
    M25(C00LANT ON)
    M5
    T0
    M1
    (FINISH FACE)
    (.015 NOSE RADIUS)
    M75
    /G99G97
    /M4S2200
    /T2300
    /G0X-1.025Z-.05T13
    /M21(ERROR DETECT ON)
    /Z.035
    /G1X-.938F.005
    /Z.0306F.0025
    /G2X-.8768Z0.R.0306
    /G1X-.43
    /Z-.05F.01
    /G0X-1.1
    /G0Z0T0
    /M5
    M76
    M1
    M75
    (RUFF ID)
    (.45-.48 DIA. REGRIND 2 FLUTE 1/2" EM)
    /T2100
    /G97S800M3
    /G0X0.Z-0.05T11
    /G1Z.564F0.002
    /G0Z-0.05
    /(SHIFT OVER AMOUNT NEEDED TO RUFF ID)X.04
    /G1Z.549
    /G2X.01Z.564R.015(CHANGE TO MATCH SHIFT AMOUNT)
    /G1X0.
    /G0Z-.05
    /G0Z0T0
    /M5
    M76
    M1
    M75
    (FIN. BORE)
    /G99G96
    /G50S2200
    /M3S2200
    /T2300
    /G0Z-0.05T13
    /X.5613
    /G1Z0.F.005
    /G3X.5Z.0306R.0306F.002
    /G1Z.564
    /X.47F.005
    /G0Z-.05
    /G0Z0T0
    /M5
    M76
    M1
    M75
    (CHAMFER .272 HOLE)
    /G99G96
    /G50S2200
    /M3S2200
    /T2300
    /G0Z-0.05T13
    /X0.
    /G1Z-.6F.02
    /Z-.65F.002
    /G04U1.0
    /G0Z-.05
    /G0Z0T0
    /M5
    M76
    M1
    M75
    /G99G97
    (EJECTION OF PART)
    /T2900(SETS UP LOCATION)
    /M3S300
    /G0W2.5
    /M14(AIR BLOW ON)
    /M11(OPEN COLLET)
    /M15(AIR BLOW OFF)
    /M5(SPINDLE STOP)
    /T2000(X AXIS HOME)
    /M84(PARTS CONVEYOR ON)
    M1
    (PART PICKUP)
    M4S3000
    M11(COLLET OPEN)
    G0Z-.250
    M68(FEED TORQ ON)
    G98(FEED-INCH/MIN)
    G1Z.6F50.
    G99(FEED INCH/REV)
    G130(ZERO,Z AXIS HOME CANCEL)
    M10(CLOSE COLLET)
    M69(FEED TORQ OFF)
    G98(FEED INCH/MIN)
    M68(FEED TORQ ON)
    G1W-.25F100.
    M69(FEED TORQ OFF)
    G0Z0T0(Z AXIS HOME)
    M5(SPINDLE OFF)
    M26
    M99(REWIND TO TOP)
    Apr 2014
    7
    Re: program for star swiss type lathe
    Hi Every one I m Kevin ,I am using GibbsCam. Can I have post processor file STAR MS-16 C with Fanuc control 18i-TB
    Email: [email protected]
    Thank You so much
  1. Replies: 6
    Last Post: 03-16-2024, 07:06 AM
  2. Need post for Star SV-12 Swiss lathe
    By bbjang in forum GibbsCAM
    Last Post: 06-04-2013, 04:34 AM
  3. Need post for Star SR-32J Swiss lathe
    By CreativeLimits in forum GibbsCAM
    Last Post: 04-25-2013, 01:37 AM
  4. Replies: 4
    Last Post: 06-23-2010, 06:38 AM
  5. Wanted: Swiss-Type Star SV-32 Parameter
    By Jung in forum CNC Swiss Screw Machines
    Last Post: 06-11-2008, 12:55 PM
