586,630 active members*
2,474 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Conversion to LCD monitor
Results 1 to 7 of 7
    Apr 2005
    345
    I am converting a VMC15XT (1994) to an LCD monitor. I purchased a kit from Earth LCD.
    XLK-12.1-VGA
    So now I have to go from my BNC cable to a D shell, anyone know if I need a connector like this from Amazon?
    [ame=http://www.amazon.com/VideoSecu-Composite-Video-Adapter-Converter/dp/B001SJDESC]Amazon.com: VideoSecu Composite Video to PC VGA Adapter BNC to VGA Converter 1L9: Electronics[/ame]
    Thanks all
    Scott
    I can post the design for the bezel to mount the monitor if anyone would find that useful.
    http://www.scpconcepts.com
    24223
    Are you sure that monitor signal is VGA? That LCD is fairly hi-res, and many of the CRT type monitors were either CGA or low res VGA and/or TTL.
    Al.
    Albert E.
    Apr 2005
    345
    Hmmm, well Al, I am not sure of anything lately! I am learning with the sink-or-swim method on this screen retrofit.
    I wonder if anyone else can answer that.....I am not sure what the 1994 VMC15 monitor resolution is......
    Jun 2012
    16
    I was able to convert to a LCD TV using a composite jumper I bought for $3.50 at Radio Shack. I removed the old CRT screen and replaced it with an Aluminum cover plate. Mounted the TV to the plate and it Works great. While the machine is busy machining parts I can change video feeds and watch movies While I work.
    Hope this helps.
    Email me @ [email protected] and I cant help you out with some pictures.
    Matthew D.
    Aug 2012
    I bought a brand new LCD TV after using relevant information about electronics from this platform. It generally helps people for making their right purchasing decision when it comes to technologies.
    Entertainment Link Visit this site... https://www.facebook.com/ilovebiggboss
    Jul 2013
    I have a crt screen damaged a Fadal machine model VMC4020, I change it to a monitor, I should do other than placing the monitor, I have to buy some converter, please help, I have the machine stopped for not having video signal
    Jun 2012
    16
    Juan un correo electrónico sobre el convertidor de BNC se envía.
  1. Replace old CRT monitor to LCD monitor
    By =aike= in forum Okuma
    Last Post: 01-16-2020, 08:29 AM
  2. RPM not see on the monitor
    By danielmk333 in forum Fadal
    Last Post: 03-21-2012, 07:48 PM
  3. Bad Monitor
    By eded59 in forum Fanuc
    Last Post: 10-21-2010, 08:44 PM
  4. monitor
    By rusticr6 in forum Haas Lathes
    Last Post: 10-25-2007, 01:06 AM
