586,058 active members*
3,389 visitors online*
    Feb 2009
    82
    BP VMC Backup
    Hello,
    When I got my used BP VMC 1000/22, I never had any disks that came with it and its about time that I want to make sure I have a backup of the settings that are required by my machine. It has a Bridgeport CIB. How can I extract a backup of all the parameters and settings to backup in case something goes awry.
    shaffin.
    Nov 2004
    3028
    In the maintenance page go to more commands. See if there is a utility there called makedisk. It was a small batch file that was intended to make a back up disk.
    For a complete back up you need a set of DOS disks. I also carry a DOS boot disk that allows me FDISK and FORMAT a hard drive.
    The most important file is the BMDCPRMS.sys which are the machine parameters. Another file to look for is LEADCOMP.DAT but not all machines had that one.
    George
    Feb 2009
    82
    Thanks George.
    After I back up the files, my intention is to be able to upgrade the software to Win98 in order to allow network connectivity - not sure yet if the Bridgeport CIB will take a network card though.
    Any thoughts on how to get this puppy upgraded? If there is a reference somewhere on the internet on someone who has done it that would be great.
    Whats the latest version of the Brigeport software on these machines?
    Shaffin.
  1. Meldas M50 ..I put the backup???
    By VIDE in forum Mitsubishi controls
    Last Post: 08-09-2012, 01:53 PM
  2. Need to backup parameters on VF2 (USB)
    By jolulank in forum Haas Mills
    Last Post: 07-12-2011, 04:19 PM
  3. How do you backup your config.
    By CATCH22 in forum Mach Mill
    Last Post: 12-21-2007, 04:13 AM
  4. SRAM Backup
    By msaiprasad in forum Fanuc
    Last Post: 12-06-2007, 08:04 AM
  5. Backup Script..
    By Rekd in forum Mastercam
    Last Post: 09-11-2003, 03:34 PM
