CamSoft has 4 methods to either Back up, Reverse direction, Inspect and Resume, Continue on or Abort.
(1) There is a REVERSE command which cuts the path in the reverse direction.
(2) The INSPECT macros allow you to stop, jog away, inspect, change tools etc and automatically come back to the point in the program and also the same location of the part to resume cutting.
(3) The ESC key that prompts th euser to either Abort, Backup or Continue on
(4) The most powerful method is MIDPROGRAM restart
Karl is right about MidProgram Restart feature but there's no need to write out your G code program backwards.
Visual Mid-Program Re-Start. When cutting sometimes you have to stop and travel in reverse (back up) on the path or other times you have to start in the middle of a program after coming back from weekend or night shift. We believe have the most advanced back up feature in the world. It's graphically. Even a novice can point to the touch screen with his finger tip or else use a mouse to tell it where to start cutting.
There are many more benefits to using CamSoft's "Visually Mid-program Restart Feature" using a mouse or touch screen, Graphically. This feature reads through the G code program to pick up offsets, tools, fixture positions, speeds, feeds, kerf, tool size and more all the way up to the position you pointed to then prompts you to press cycle start when you are ready. This is the easiest and smartest program resume feature we have ever seen. If you have a touch screen it will find the mathematical intersection of your finger tip to the part geometry in 3D. You can even click midway through a cut on a 3D line or arc. It does not require a back up re-cutting an already cut area twice. It is faster to re-start on portions of the part that are too far away to back up through. It can also be re-started days later. No G code to look up, no searching for coordinates in a file and no need to start at the beginning of a N block or G code line. You can start mid-way through a move. Perhaps re-start only a 1/4" before the last cut ended. It doesn't matter if the line was 100 meters long or you start at 8 o'clock around a full circle. It's visual using 3D graphics. A novice operator can do it.
There are some rules associated with these features so please look up these commands in the manual. They get into advance topics with many options to explain here.
Tech Support
CamSoft Corp.
[email protected]
PH 951-674-8100
Fax 951-674-3110
PC Based CNC Control For The Machine Tool CNC Retrofit And CNC Controller OEM Market
