What if, an E series collet extention was machined to accept the proper bearings, then coupled a short splined shaft, similar to a drill press, then to a holder and mounted to the Z axis carriage. The Z axis servo would then be mounted, where the hand crank would be on a drill press, and the spindle motor could be mounted, and used as a counter weight, on the opposite side of the X axis way, where it could also be drive from. This would counter any X axis flexing, theoreticaly of course. I recently tried to use a 1.5 hp motor as a spindle drive, and the wieght, caused the X axis way to flex in a counter clockwise direction. In practice, this concept, would essentialy mimic that of a Bridgeport style machine only on a smaller scale. The sizes commonly built here among our members. Any comments on the practicality of such a setup?
