586,096 active members*
3,569 visitors online*
    Dec 2010
    Unhappy Hartford HV50 axis board
    Hi Guys
    I have a Hartford V50 with a feed hold that doesn't work...
    The fault has been traced to a board, part number HV-S-M500-A, at X59 pin 8
    Does anyone have a schematic, spare boards or clues how to sort this? I desperately need to get it going but we seem to have no support in the UK for this stuff.
    Feb 2012
    27
    How old is the machine and what control does it have Fanuc?
    i run a Hartford HV60 1995 Fanuc OM control at work.
    The most parts to the machine are still possible to get from Hartford in Tawain.
    Is there no reseller for Hartford in the UK?
    Dec 2010
    Hi tkgb
    The control is a Mitsubishi control, similar to Fanuc. Machine is 1997 I believe. I have just had the board checked and all the relays, diodes, resistors and coils are all OK, so the fault lies elsewhere. Tomorrow I will try to bell out the cables, but without a diagram it will be tough. I will try Hartford in Taiwan tomorrow to see if I can get a schematic...
    Jan 2011
    If you have a Mits control then Mits Elec Europe should be able to
    sell you a board.
    CNC parts operations are handled by Mits in Germany
    Mitsubishi CNC Europe
    If they cant help you Mits Americas
    might be able to sell you the part
    www . meau. com
    Apr 2022
    11
    Re: Hartford HV50 axis board
    Hello, I have a Hartford VMC-1020 with Fanuc O-MD system, but the PMC ladder diagram is lost. Could you please send me an OE1/OE2 file? Thank you very much!
  1. Hartford VMC-1270A Spindle
    By Green Button in forum DNC Problems and Solutions
    Last Post: 07-22-2011, 10:55 AM
  2. HURCO vs. HARTFORD vs. HASS
    By sthomas in forum Want To Buy...Need help!
    Last Post: 06-30-2011, 08:47 PM
  3. hartford
    By jamesrnz in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2009, 12:03 AM
  4. Hartford CNC
    By phc in forum Bridgeport / Hardinge Mills
    Last Post: 06-19-2006, 07:01 PM
  5. Hartford townee?
    By praetor in forum Vertical Mill, Lathe Project Log
    Last Post: 01-26-2006, 02:20 PM
