586,119 active members*
3,473 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Miyano TSV 21 ATC Program required
Results 1 to 5 of 5
    Aug 2012
    I have a 1986 TSV21 Miyano make drill tap center.
    I had to reset machine memory, i have backup of all except ATC programs, which are 9000,9001 etc.
    If any one can please give me the same, I will be very much thankful.
    Regards
    A.C.****ole
    Sep 2009
    91
    amarcs
    This i ATC macro from Miyano TSV21 with Fanuc OM control.You can change program No.9003 to 9000 and will not have problem
    O9003
    G04
    G65H81P800Q#1000R1
    G65H81P800Q#1004R1
    G91G28Z0M19
    G49
    G65H82P250Q#1001R1
    M80
    G65H82P350Q#1006R1
    G30Z0
    G65H82P450Q#1003R1
    M82
    G65H82P550Q#1004R1
    G28Z0
    G65H82P650Q#1002R1
    M81
    G65H82P750Q#1005R1
    M99
    I have two Miyano TSV21 but with one of them i have ATC problem because machine came without parameters.I installed now and everythink works except ATC.I think that is incorrect parameters.Can you send me your beck up of the parameters and pic from operating panel to try it.I will be thank full.If you need somethink else my mail is [email protected]
    Oct 2012
    21
    Quote Originally Posted by amarcs View Post
    Regards
    A.C.****ole
    Have you asked Miyano? I have no experience of Miyano but i have had other "identical" machines with different ATC macro programs before.
    Ben
    http://www.cncapplications.co.uk
    Dec 2010
    31
    Re: Miyano TSV 21 ATC Program required
    Any body can help me how to zero reference ATC of Miyano ATC-21 with Fanuc OM control Year 1989. OR may send me photo of Manual pages contain how to zero reference ATC. Earliest response appreciated. Thanks, Ejaz , [email protected]
    Aug 2020
    3
    i am also facing the same problem if you have solved your problem then do let me also know how did that happen so that i can also solve the problem.
    regards
    abhishek drolia
    93two80two3280
    india
  1. Replies: 1
    Last Post: 05-26-2012, 09:29 PM
  2. Miyano program help
    By extanker59 in forum G-Code Programing
    Last Post: 03-02-2012, 02:16 PM
  3. Miyano BND 42s program wont loop
    By Morgan111 in forum Uncategorised MetalWorking Machines
    Last Post: 01-12-2011, 12:24 PM
  4. Help required: simple software to program Laser cut machine
    By manutitou in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-13-2009, 10:30 AM
  5. Replies: 4
    Last Post: 05-05-2007, 03:49 PM
