Hi all,
I have a 3kW Chinese spindle and 3kW VFD. I did a factory reset, and programmed what I think are all of the necessary parameters. The problem is that when I try to turn it on it jitters a little before starting, if it starts at all. Sometimes it just buzzes until the drive faults. If it does start it's not always in the corrrect direction. If I spin it fast enough by hand before starting, it will go the right direction. Once running it is smooth and quiet.
I messed with the mid voltage and frequency (staying pretty close to the factory presets), and starting frequency with not much luck.
Any suggestions would be appreciated!
