586,667 active members*
3,672 visitors online*
    Nov 2007
    18
    10m zero return
    I have a Fanuc 10M on a mycenter 0 that overtravels in "y" on zero return. I know on a 0M control you can press P + Cancel while turning on the control, to fix some z/r issues. What is the majic code to do this w/ a 10M control.
    There isn't one. The series 10 doesn't look at the soft over-travels until the machine has preformed a manual reference. I suspect that you are going into "hard" over-travel rather than "soft" (P-CAN ignores "soft"). What you can do is move the slide as far as you can in the opposite direction. Then manually trip the decel dog before it gets near the real decel dog. If the slide continues to travel all the way to the real decel dog then your motor encoder is not outputting the Zero pulse or the switch is malfunctioning. You should be able to see the decel input on the PMC diagnostic page. If it homes mid slide then you may be too close to the home switch when starting or the over-travel switch is too close to the home switch. Hope this helps
    Nov 2007
    18
    Thanks for the info. it goes into "soft" over-travel. I'm gonna try your way, I'll let you know if it works.
    well You have one way:
    turn off machine.
    press "." and "," ( point and comma) and turn on machine.
    on screen appear
    IPL MODE, and options 1 to 6
    press 4, after that Y and input .
    after that 6 and input.
    Now machine is in normal mode without software OT checking, like P+CAN on 0 system.
    regards djordje
  1. z return
    By Clyde_06 in forum Surfcam
    Last Post: 11-16-2011, 06:45 PM
  2. zero return sub
    By rylanrouge in forum Uncategorised MetalWorking Machines
    Last Post: 07-18-2011, 02:50 PM
  3. Tool eye won't return
    By extanker59 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-26-2009, 03:27 PM
  4. Zero return
    By bubba107 in forum EMCO Mills
    Last Post: 10-22-2009, 01:49 AM
  5. Return to Zero
    By mikemill in forum Machines running Mach Software
    Last Post: 08-25-2009, 08:47 AM
