586,408 active members*
2,979 visitors online*
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Aug 2018
    I need a parameter because I loat all parmtr of machine I have no back of this please send me on [email protected]
    Best regards,
    Jayavant
  2. #22
    Torrent might not getting indexing signal due to following reasons:-
    1. Sensing tenet on back side of turret might be loose due to which it is not getting stop signal.
    2. Or it might be due to sensor signal drop for some wiring related reason or loose wiring.
  3. #23
    24223
    Re: FANUC 0T parameter problem
    Quote Originally Posted by Jayavant View Post
    Best regards,
    Jayavant
    You need to find someone with the identical model of machine. what is make/model Number? They are all dependant on how the machine was commissioned by the OEM.
    You also require the option parameters that were purchased when machine was commissioned.
    Al.
    Albert E.
  4. #24
    May 2020
    10
    Hi, I have a Jonhford TC20 with a control Fanuc 0-T, the problem with the turret is that it indexes well manually, but lately when running a program we realized that the turret kept turning and keeps moving as if it were in the correct position, if you could provide me your parameters to see if that solves my problem or any advice to follow, best regards.
    e-Mail: [email protected]
  5. #25
    Feb 2021
    Good day,
    I seem to have exactly the same problem. I would appreciate it if anyone can help me and send me all the correct parameter & diagnostic settings to [email protected]
    Thank you,
  6. #26
    Feb 2022
    I have a similar problem with my ZL15-S, Fanuc 0-T B. I need to reset the machine parameters. When resetting the machine, the default is MDI mode, I can't change to EDIT. When I manually enter parameter 905, the machine blocks me from editing the other parameters.
    Maybe someone of you has already encountered this problem and could help.
  7. #27
    Dec 2009
    957
    show us the complete 905 parameter,i think you put a bit that is not supposed to be enabled
  8. #28
    Feb 2022
    The list of parameters in the attachment.
Page 2 of 2 12
  1. Om Fanuc parameter problem
    By Dean Monarch in forum Fanuc
    Last Post: 04-12-2014, 07:55 AM
  2. Fanuc OT parameter problem (EMCO 320 Lathe)
    By archfact in forum Fanuc
    Last Post: 03-17-2014, 08:48 PM
  3. Replies: 5
    Last Post: 03-24-2012, 08:07 AM
  4. fanuc 6t parameter problem
    By moghul in forum Fanuc
    Last Post: 12-30-2011, 07:59 PM
  5. Fanuc OM ATC parameter problem
    By techscan in forum Fanuc
    Last Post: 09-18-2011, 04:49 AM
