586,385 active members*
3,337 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Could use help, finding datasheet for motor.Thanks
Results 1 to 6 of 6
    Aug 2012
    VEXTA INTERMEC Model C6925-9212K 2 Phase Nema23 Stepper Motor
    Looked everywhere. Seems Vexta doesn't want to help either. Would much appreciate a datasheet, or wire description.
    Thank You.
    Dec 2003
    24223
    That is not a common Vexta number, most likely a OEM special.
    Al.
    Albert E.
    Aug 2012
    Some more info from seller.
    NEMA 23 size, 2 phase, 1.8 degree per step, stepper motor, model C6925-9212K. The motor is marked DC 3.4V, 3A, with a 1/4 inch round shaft and It is from a spare part assembly for a commercial printer (INTERMEC)
    and a picture: Click image for larger version.
    1943
    Call Vexta (oriental motor). I had a Vexta Nema 23 I needed specs for and I called them. Had the spec sheet in my e -mail inbox about 1/2 hour later.
    1-800-go-vexta
    Aug 2012
    Called vexta, they said they don't have a datasheet for this motor.
    Aug 2013
    Wiring
    Red = A
    Blue= -A
    Green = B
    Black = -B
  1. Datasheet for Stepper Motor needed
    By aticio in forum Stepper Motors / Drives
    Last Post: 12-20-2008, 04:53 PM
  2. Stepper Motor datasheet request!
    By leitox in forum Stepper Motors / Drives
    Last Post: 07-03-2008, 04:51 PM
  3. Datasheet for STP-58D207-01 (Step motor)
    By duykhoi02cdt in forum Stepper Motors / Drives
    Last Post: 04-03-2007, 04:50 AM
  4. Siemens Motor Datasheet Source?
    By GrindEngineer in forum Servo Motors / Drives
    Last Post: 01-09-2007, 02:46 PM
  5. help with stepper motor datasheet/specifications
    By zoltan in forum Stepper Motors / Drives
    Last Post: 08-11-2005, 09:12 AM
