586,728 active members*
3,581 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > My laser engrave wont trace objects, only cuts using horizontal or Vertical paths
    Jul 2012
    Hello Everyone,
    Im new to posting but have been reading and looking through here for a while,
    I recently aquired a 50watt co2 Laser engraver,
    a ZTGD-4028D Artware Engraving Machine,
    I seam to be getting it down pretty well,
    Iv made about 40-50 pendants, bracelets, masks, lots of art pieces etc etc
    but after looking online at videos I noticed that my machine is only cutting/engraving on either the Horizontal Axis or on the Vertical Axis,
    It takes me 1-2 hours to cut out a simple small circular pendant.
    I know that I could do these way faster (a few minutes) if I could get it to follow curves while cutting.
    I wish I had a video camera to show you what I mean, but am hoping that someone here will know, and can point me in the right direction to get this thing working better...
    Also, when cutting/engraving using the horizontal axis, it messes up alot and starts moving around while engraving the images. creating a very chopping engraving that looks like crap =(
    The vertical axis it only seams to happen 1 out of 20 projects or so,
    vs with the horizontal its almost every project if not 1 out of 3
    I included a few photos of the pendants iv been making below as well,
    Attached Thumbnails Attached Thumbnails _MG_0373.jpg   _MG_0236.jpg   _MG_0232.jpg   _MG_0234.jpg
    Feb 2009
    123
    cut / engrave
    hi there
    your pendants look great!
    it sounds like the difference between CUT and ENGRAVE.
    eg. CUT = following a vector path, either on lower power/higher speed to mark a line on the material, or on higher power/lower speed to cut through the material.
    eg ENGRAVE = rastering / scan lines usually in horizontal X axis on most machines. a vector or bitmap image is then built up from successive scan lines.
    i would expect those pendants to take 5 minutes each. ( mostly for engraving the surface detail, a few seconds to cut the outline!)
    What software are you using to drive the laser ?
    regards
    KPB
  1. Laser cutter wont cut/engrave
    By jassk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-14-2013, 01:26 AM
  2. Non vertical cuts....adding a THC?
    By HakBot in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-12-2012, 09:29 PM
  3. horizontal and vertical control
    By makenparts in forum Bridgeport / Hardinge Mills
    Last Post: 05-18-2011, 12:49 AM
  4. carusel horizontal o vertical
    By matriceria_fae in forum Spanish
    Last Post: 08-08-2010, 02:30 PM
  5. Horizontal / vertical mill How to post ?
    By vsengineering in forum Mastercam
    Last Post: 07-27-2010, 08:48 AM
