586,441 active members*
5,240 visitors online*
    Apr 2012
    11
    DX-32 Problem
    I am running a Bridgeport VMC 1000 Mill controlled by DX-32. When I program a tool change, the spindle turns off like it is supposed to do, but I get a message that says "Spindle not up to speed in time" Then the drives shut off and I have to restart everything. What do I need to do to keep the error message from coming up and shutting everything down??
    Jan 2018
    44
    Re: DX-32 Problem
    Did you ever figure this problem out? My machine is doing the exact same thing.
    Aug 2009
    1573
    Re: DX-32 Problem
    ...Backup all MTB param's write them down ASAP before something else fails during troubleshooting anything would be my advice to start> then ...power supply voltages would be the 1st to suspect to do age.
    Merry Xmas
  1. Having problem with CNC driver/card problem
    By todatop in forum Commercial CNC Wood Routers
    Last Post: 04-09-2014, 05:45 PM
  2. Tube problem or powersupply problem? Help you to check out
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2012, 04:09 AM
  3. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  4. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
  5. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
