586,051 active members*
3,870 visitors online*
    Apr 2012
    Agie Mondo 30 Cutting Depth
    I'm running two Mondo 30 EDM's and neither one will cut to the programmed depth. I'm touching off with each electrode and they still cut about .003-.005 shallow where I'm looking for plus or minus .0002. Anyone have this problem or a possible solution. Thanks, Chuck
    Mar 2015
    two things happen here.
    1. There is always some stuff between the electrode and the part , so electrical touching is usless. I use a mechanical setup (gauge block )
    2. Even if you EDM only 0.2 - 0.5 mm , your electrode will erode. Solution : I add an extra .05 mm to every burn depth
    by default
    Gracjan
  1. Agie/Elox Mondo 30 cnc help needed
    By dannystooblue in forum Waterjet General Topics
    Last Post: 04-30-2015, 03:59 PM
  2. Cutting depth issues
    By NylonAdmiral in forum Mastercam
    Last Post: 10-14-2009, 04:07 AM
  3. Cutting speed and depth
    By MechanoMan in forum Benchtop Machines
    Last Post: 03-08-2009, 01:03 AM
  4. Setting cutting depth
    By awemawson in forum FeatureCAM CAD/CAM
    Last Post: 10-30-2005, 10:05 AM
  5. Possible to have more than 1 Cutting depth?
    By CJL5585 in forum SheetCam
    Last Post: 06-02-2005, 10:44 PM
