586,119 active members*
3,694 visitors online*
    Apr 2011
    Gear or Spline
    Hi guys,
    I have been trying to program this shape so that i can wire a new spline on a shaft we have but I have had no luck.
    have tried to work out the paths from the following data.
    image of shape and data is attached
    I would appreciate any help or gcode paths for wiring.
    Eyesociety
    Aug 2013
    4
    Do you still need this doing? I could probably model it up in Catia and then spit out some G Code
    Apr 2012
    23
    If you still need this I can generate a profile as well.
  1. Bevel Gear Cutting with Involute Spur Gear cutter
    By basalt in forum MetalWork Discussion
    Last Post: 05-06-2012, 10:13 PM
  2. Basic Bevel Gear - Milling a valley for gear teeth
    By ngr1 in forum Uncategorised CAM Discussion
    Last Post: 04-05-2012, 03:55 PM
  3. Single Point Gear Spline Broaching?
    By Jake@SRM in forum Haas Mills
    Last Post: 02-13-2012, 12:26 PM
  4. What size gear belts for stepper gear reducer?
    By Danno in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 09-28-2011, 10:28 PM
  5. Need a Lagun Lathe Gear or Custom Gear Maker
    By douglasco in forum Uncategorised MetalWorking Machines
    Last Post: 01-12-2011, 03:54 PM
