Does anyone have the parameters for a Bridgeport Series II Interact 4 TNC 155 and does anyone know where to find a service manual?
I'm experiencing the same problem, I lost the parameters of my interact 4 series II with TNC155, if someone have these parameters I'm interested as well! Thanks
Srussel, if you mean the Bridgeport manual, I'll start to scan mine tomorrow, if you need a specific information don't hesitate to ask!
François
Is this what you are looking for?
http://content.heidenhain.de/doku/om...a/gb/sa155.pdf
Measurement and Control Technology for Demanding Positioning Tasks | HEIDENHAIN
Scan completed, you can download the pdf of the maintenance manual with this link:
Bridgeport interact 4 series II Maintenance Manual
I hope it can help.
François
Thanks for the manuals. They both will help alot.
Dear Francois,
A couple of years ago you posted link of a manual for an interact 4 series 2, but that link is not working anymore.
I have the same machine, but no manual.
Would it be possible to put it online again,
Regards,
Manuel
Here's a copy of the parameters the previous owner of the machine sent me last week, limit switches need to be adapted (procedure described in the mill's manual) and a few others to your preferences.
I had an issue with the x axis which would overtravel after the limit switch, it was fixed by Gridley51 (once again) by changing the parameter 20 from 1 to 0 (counting direction).
The maximum speed is set at 3750 in these parameters but should be 4000.
Except these things my mill (interact 4 series II with tnc 155b) works as well as before losing the parameters, so it should be ok for you too.
Good luck.
François
