586,103 active members*
3,684 visitors online*
Thread: MAHO 500
    Jul 2012
    MAHO 500
    Hello!
    I have a problem with MAHO 500 machine...Z axis available distance reading is 9999 mm on machine's monitor while same thing for x and y axis is about 1000 mm ( lathe length ). So my question is why machine reports such enormous travel distance available for z axis while for other two is normal?
    Parameter settings are same as before when everything's was ok so that's not the problem.
    Machine PLC has been fixed twice with assurance from technician that now functions OK.
    Another thing..when referent points are to be found z axis driver push that axis all the way up and if i don't reduce feed rate to 0 it would collide with y tool head. It never finds referent point because its way down on lathe.
    Does anyone has some ideas about this strange behaviour?
    Jun 2013
    5
    u can try to look at the parameters if u have the book it show's u each one what it means. u have in the electrical box 3 switches u need to turn one on to make changes the one in the middle i think. Sorry for my bad english hope i can help you. if need some thing alse ask me . and please tell me what type of maho 500 is? 500c 500e 500w?
  1. Maho MH 600 P
    By CNC Metal in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-18-2010, 01:30 PM
  2. WHAT OIL TO USE / MAHO 700 P
    By percy in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-18-2009, 11:54 PM
  3. maho mh 700 p,what r they like
    Last Post: 02-14-2009, 07:21 PM
  4. maho mh 700 p,what r they like
    By percy in forum Want To Buy...Need help!
    Last Post: 02-04-2009, 02:41 AM
  5. Maho MH 600 P
    Last Post: 01-31-2008, 02:41 AM
