Hi all!
I do a lot of Mill/Turn programming and i routinely program using all three planes in the same program.
The problem is I need a Mill/Turn config so I can plot from start to finish.
Right now I devide my program up into seperate lathe and mill portions and then join them together after they are finished. That gets me through most of the time.
Sometimes when I am programming say... NPT threads in G19 using a incremental style then that will not run in a mill config it seems because of all the W's and V's.
Does anybody else out there have trouble with this? What are you doing to get around it?
Thanks, Mike
