586,377 active members*
3,075 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Master cam version 9.1
Results 1 to 12 of 12
    Aug 2012
    im trying to make a contour cut on a piece of stone using master cam 9.1.. it makes the cut but it makes the cut then raises up at the end then goes back the the bigginning.. im trying to figure out how to make the bit stay down so it will start at one end and go down 1/8 then at the end make the tool stay down and cut down another 1/8 so it will finish my piece quicker..///
    Apr 2003
    3578
    on your depth cuts did you tell it to keep tool down?
    Cadcam
    201
    That all depends on the part that I am cutting.
    Apr 2003
    3578
    Mow Jimmy pops in after a few years. hello sir.
    Cadcam
    Mar 2008
    683
    endpoints
    Make sure all the endpoints actually meet up. It looks to me like there are gaps in your contour.
    201
    sorry, I have been very busy. I miss being here.
    Aug 2012
    yes i went to depth cuts and clicked on keep tool down.. and it still brings my bit up from the end of the contour to the bigginning then goes back down..
    Aug 2012
    it cuts the contour correctly but im trying to make the cut faster by kepping the tool down instead of the tool going back up at the end of the contour on every pass
    Oct 2010
    21
    you can use "ramp" option in contour toolpath
    Cad Cam Cmm E
    201
    if you use the ramp option to cut a open contour it will climb and conventional cut down the contour. If you want it to only climb cut then telling it to keep the cutter down should keep it down. Hope this helps.
    Aug 2012
    using the ramp option solved my problem... thanks for the info people...
    201
    anytime
  1. IF I HAVE A OLDER VERSION SAY MASTER CAM 9
    By bobrob in forum Mastercam
    Last Post: 08-06-2017, 09:43 PM
  2. powermax 45 machine version vs hand version
    By landmark in forum Hypertherm Plasma
    Last Post: 02-14-2010, 11:13 PM
  3. how to tranfer old version post to new version
    By ming035 in forum GibbsCAM
    Last Post: 02-11-2010, 08:08 PM
  4. Newest version of Mach3 Version 1.90.065
    By turmite in forum Mach Mill
    Last Post: 01-27-2009, 04:21 AM
  5. Replies: 2
    Last Post: 12-12-2006, 12:12 AM
