586,051 active members*
3,721 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > Low air pressure error and I've replaced lots already... help?
    Aug 2012
    Question Low air pressure error and I've replaced lots already... help?
    I run a Multicam 3000, not even two years old, and recently I got a MODBUS TIMEOUT error, adjusted the wires connecting to the RIO board, working for the moment. since then I've had to replace two of the solenoid at the top of the spindle area to stop a air leak, followed by continuing errors saying there is Low Air Pressure, I have adjusted the air pressure sensor but to no avail.
    I currently have a little red light on the top of the #2 solenoid. I've removed the solenoids to be sure there is not debris visible in or on the air manifold.
    Fiddled with more wire connections to be sure they were connected well.
    ...I'm running out of ideas. Got any?
    Thank,
    JOE
    May 2004
    4519
    Call MultiCam.
    Jan 2006
    2985
    Check incoming air pressure.
    Increase incoming air pressure.
    Check for sticky solenoid valve or clogged filter/lines.
    Replace pressure switch.
    Verify pressure at pressure switch with gauge.
    Remove pressure switch and test connected directly to air source.
    Check wiring to/from pressure switch.
    Find out which wire does what and bypass pressure switch as a temporary test to see if the switch is at fault.
  1. Replies: 5
    Last Post: 07-03-2012, 08:21 AM
  2. LB15 shear pin replaced what know ?
    By meadowtech in forum Okuma
    Last Post: 06-22-2011, 12:36 AM
  3. X-axis motor replaced -> problems
    By FinnCNC in forum Fadal
    Last Post: 08-20-2008, 10:13 PM
  4. replaced 202s with 201s
    By wes in forum Gecko Drives
    Last Post: 07-15-2008, 06:03 PM
  5. Replies: 40
    Last Post: 02-08-2008, 12:03 AM
