586,114 active members*
3,375 visitors online*
    Apr 2011
    31
    Torq cut tc3 issue - BMDC??
    Hi, Not sure if this is a BMDC problem or what. The mill was running and then the table stopped but the spindle kept running. Pushing the start/stop button just made clicks. I tried turning the machine off. On turning it back on, all the axis would home, but would get an error message to re-load tools. Trying to re-load tools would just result in a click. The table would also not jog. So, I go into the 'maintenance page.' I could re-load the tools from there. Then I ran the BMDC test program, B3T.EXE. It came up with the error on the Analog test: "Expected ADC Z axis value is C0, ACD value is BC." And "ADC error!! - not reading zero value properly." If I ran it thru many times, sometimes the expected values/ actual values would be different, but over 90% of the time,there would be such an error. All the other tests for the BMDC board would be fine.
    So, am I looking at needing to repair the BMDC board, or is there another issue perhaps with the z axis drive or such?
    Greg
    Apr 2011
    31
    I have tried reseating the BMDC board, checking the PSU on the CIB. All to no avail. In running the Analog test again, I noticed that it's all of the axis, not just the Z axis.
    Any ideas? Bad board?
    thanks
    Jul 2005
    181
    Can you put the drives ON? Are you able to do a homing?
    Apr 2011
    31
    I had started this thread
    http://www.cnczone.com/forums/bridge..._torq_cut.html
    I was thinking that I was needing a repair service, but, if by looking at what I've done as described in this new thread you have suggestions, please do respond.
  1. BMDC
    By tpmx57 in forum Bridgeport / Hardinge Mills
    Last Post: 06-17-2011, 02:16 AM
  2. Bridgeport Torq Cut 3g spindle speed issue
    By scrap maker in forum Bridgeport / Hardinge Mills
    Last Post: 04-19-2011, 03:05 PM
  3. BMDC
    Last Post: 10-12-2010, 07:42 AM
  4. Bridgeport eztrak bmdc
    By dreammstr6 in forum Bridgeport / Hardinge Mills
    Last Post: 08-12-2010, 09:10 PM
  5. Need help with a Bridgeport BMDC issue...
    By ralph@nes in forum Bridgeport / Hardinge Mills
    Last Post: 02-26-2007, 03:30 PM
