586,033 active members*
3,430 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Contouring Violating Surfaces
    Aug 2012
    Hello,
    I am new to Cimatron. Can you set it so will automatically know where each surface is and not violate/ crash into the surfaces, even if I didn't select them, set any bounds or set check faces?
    Thanks in Advance,
    Hades
    Jun 2011
    If there is a way to do this I have not found it yet. As far as I can tell if you don't
    select them or define them as check surfaces basically Cimatron will not see them. If your maintenance is up to date I would give them a call and i'm sure you will get an answer right away.
    Jan 2012
    pick all surfaces by criteria
    Just set up your template to pick all surfaces by criteria, probably by "entity type" would work best. The type to check would be "FACE".
  1. Contouring Violating Surfaces
    By 66hades in forum Mastercam
    Last Post: 08-28-2012, 04:54 PM
  2. Help with contouring
    By gsnorcal in forum SprutCAM
    Last Post: 11-17-2011, 08:07 PM
  3. 2d Contouring
    By scottsss in forum SprutCAM
    Last Post: 10-04-2011, 11:48 PM
  4. 3D Contouring????????
    By cut2spec in forum Benchtop Machines
    Last Post: 03-18-2007, 07:08 PM
