586,089 active members*
3,867 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > How to control A axis rotation in negative direction?
    Mar 2009
    139
    Sherline 4-axis mill with Mach3
    I ran a gcode of a 4 axis toolpath and noticed that wherever the A value decreased even a fraction of a degree, the A axis made a full revolution less the degrees of the difference.
    To clarify....if the code was A310 going to A312, the rotary axis would move clockwise for just those 2 degrees (cool) but if the code was A310 going to A308, the A axis would rotate clockwise for 358 degrees.
    The little test I want to run has hundreds of line with decreasing A values. How do I prevent an almost 360 degree clockwise rotation of the A axis if a 2 degree counter-clockwise rotation would do the job more efficiently?
    The A axis, works correctly via keyboard input.
    EDIT: I found it. Un-tick ROT 360 ROLLOVER...Right?
    Norbert
    Nov 2003
    126
    As soon as I read your post I was going to suggest the 360 Rollover thing. Did that fix it for you?
    Apr 2007
    151
    To control your 4th axis, code is either A No of degrees or -A No of degrees.
    As all axis use minus sign to send in oposite direction.
    Mike
  1. Replies: 8
    Last Post: 08-22-2010, 09:09 AM
  2. Lathe - X axis positive/negative?
    By sansbury in forum BobCad-Cam
    Last Post: 08-20-2010, 03:58 PM
  3. 2.5 Axis Direction Control
    By ee_cnc in forum LinuxCNC (formerly EMC2)
    Last Post: 11-21-2007, 03:42 PM
  4. Rotation control help on A axis
    By Art Ransom in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 01:04 PM
  5. Large A axis (rotation) control HELP!!
    By Art Ransom in forum Community Club House
    Last Post: 09-05-2006, 10:11 PM
