586,116 active members*
3,442 visitors online*
IndustryArena Forum > CAM Software > Mastercam > process file to large
Results 1 to 6 of 6
    Aug 2012
    Hello, using mastercam X5 working on tutorial 4-2 ? it looks like a plak and says 101 MASTERCAM having trouble loading the file into an okuma mill, file to large, I have a process for ea. tool change and the file is still to large the 1/4" pocket and the 1/8" re machining process are very large by them selves they are more than 200KB the okuma only allows about 137KB. Any ideas greatly appreciated.
    Thank you
    Greg
    201
    You can play with the filter to shorten the code. That would be one way to do it. If your filter is set real tight you will get longer code. Know your tolerance and adjust your filter accordingly.
    Aug 2012
    Thank you.
    like the post says "newbie"
    I just started school this summer quarter
    I have a pour instructor.
    I will look into the filter and tolerances.
    Thyank you
    Greg
    Oct 2009
    i can help with that
    Delete your line numbers. then delete all of the spaces in your code. I have the same problems with my Okumas.
    Dec 2008
    3109
    If you have depths set, try using sub-routines (not sub-programs, it puts the subs after the M30, in the same program ).
    a big saving if you have say 20 depths of a single pocket, where a single pocket pass is 10Kb ... thats nearly 200Kb
    Note
    There are no subs available if surfacing, & no real benefit to sub, if you have single pass ops (ie single pass finishing )
    201
    it's ok to be new at this. That is way these forums are do nice. forums are a great tool to have.
  1. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  2. EMC2 not reading large Gcode file???? HELP
    By autorouter34 in forum LinuxCNC (formerly EMC2)
    Last Post: 09-12-2009, 06:42 PM
  3. Large File?
    By esadaddy in forum Fanuc
    Last Post: 01-16-2009, 06:46 AM
  4. Free Large File Transfer Software
    By angelstar in forum OpenSource Software
    Last Post: 04-26-2008, 10:10 AM
  5. In the process
    By Smitty911 in forum Dolphin CAD/CAM
    Last Post: 05-10-2007, 06:34 AM
