Albrow
Thanks for the reply. However, I did indeed go to Lowe's with my trusty digital calipers and did some measuring (side note: you should have seen the looks on the faces of some of the employees when I started doing this). The "water pipe" that I had looked at on their website is galvanized steel, not copper. I measured the inside and outside diameters of both the 1" and 1/2" pipe, and all measurements were within a few thousandths of an inch of those listed in the schematics. I'm linking the ones that I'm going to use below:
1/2" pipe
1" pipe
Those lengths are due to the oversize of my build, but there are plenty of lengths available through either their website or in the store.
Finally, I thought I had recognized your name from other threads that I'd browsed through, so I looked you up on this site. As soon as I saw the pictures of your Z Axis made from HDPE, I remembered. I'm wondering how that worked out for your build? I ask since as soon as I get mine up and running, one of the first things I'm going to do is use it to recut some of my parts, and had considered using some material other than MDF.
Cheers, and thanks for the info.
-Rusty
