586,121 active members*
3,483 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Can't get I,J,K based toolpaths when using surface tool
Results 1 to 8 of 8
    Dec 2009
    16
    Hi all, I've posted a few times and have always gotten help so here goes.
    I'm cutting a simple concave sphere and when gibbs generates the tool path it uses thousands of linear x,y movements instead of generating radial I,J,K arcs. I'm left with a choppy faceted surface that's no good to me in my application (Optical field)
    A) Does that make sense
    B) What can I do to make it generate the kind of tool path I'm looking for.
    Any advice would be helpful
    Thanks!
    May 2004
    4519
    First, on the tool path tab of your operation, select Arcs. If that does not help, then this is probably based on your post processor you are selecting. Try different post processors.
    Dec 2009
    16
    Thanks for the tip. I see the arc generation in the g-code now, issue is It's only when I select lace cut that it allows for the option? Lace cut is no good for my application.
    May 2004
    4519
    One of several limitations of GibbsCam? What version are you using?
    May 2009
    393
    Smile
    Every CAM software outputize the NC Program through various techniques. If you try Delcam Powermill, then you have the following output options -
    1. FIT ARCS
    2. TOLERANCE ARCS
    3. TOLERANCE & FIT ARCS.
    I think that your problem is something similar one ( In your CAM Software ...GibbsCAM )
    I can provide you a NC Program (containing I,J,K values). Please mail me your Model on [email protected] & also mention the various parameters (like Stepover, avaliable cutters, stock, feed, speed).
    Ashish
    Get your CAM Programs rotated by CAS software to REDUCE SETUP TIME on your VMC & HMC. To download it, visit www.computeraidedsetup.com
    Dec 2009
    16
    I'm using Gibbscam 2009 v9.3.9
    Aug 2006
    124
    Most machines are not true 3 axis. They are 2.5 axis. So you can generate arcs on any two planes. Or make helical arcs in Z. Arcs that are on XZ or YZ planes will give G2 or G3 output. Unless the arc is perpendicular to one of the 3 axises you have to have point to point output or have a true 3 axis machine.
    May 2005
    2502
    Quote Originally Posted by Species8472 View Post
    Species makes a good point. If you can choose a toolpath that aligns the line segments so they are parallel to one of the G17/18/19 planes, you can then run a piece of software that will do arc fitting. This is standalone software that just processes your g-code and converts lines to arcs where that fits a tolerance you specify.
    Ironically, I just wrote a blog post about this faceting problem:
    7 Software Excuses for Bad Surface Finishes « CNCCookbook CNC Blog CNCCookbook CNC Blog
    Gibbs may even have an arc fitting option or there may be an add-on for Gibbs.
    Best,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
  1. Surface Parallel Toolpaths - Rolling & Cut Direction
    By daedalus0x1a4 in forum Mastercam
    Last Post: 10-12-2011, 10:48 PM
  2. reversing toolpaths on surface contour
    By galaxyman7 in forum Mastercam
    Last Post: 02-21-2010, 09:50 PM
  3. Surface pocket toolpaths
    By jcnewbie in forum Mastercam
    Last Post: 10-24-2009, 11:25 PM
  4. Surface Toolpaths
    By Flying Scot in forum Mastercam
    Last Post: 02-06-2008, 01:06 AM
  5. Surface toolpaths Help
    By Julian M in forum Mastercam
    Last Post: 10-06-2006, 09:31 PM
