586,036 active members*
4,107 visitors online*
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Oct 2003
    128
    Ok found out Bobcad does not play well with arcs = 0 so I am using arcs = 1
    I cleaned up the artwork a bit and made 2 programs with the same geometry, one for the Camsoft and one for my Fadal CNC 88. The Fadal runs it fine. Does that help figure out the problem? I have to believe it is something simple I am missing.
    I know, why don't I just used the Fadal? The material is really too big to fit the machine without taking the ends panels off, even though it looks like I will do that. And I just spent a week mounting a 24,000 RPM spindle on my Camsoft/Bridgeport so I could do this job.
    Here is a section of offending code
    N330G03X-4.537Y-.4361I-.2388J.184
    N331G03X-4.5267Y-.3674I-.2353J.0706
    N332G00Z.1
    N333(JOB 1 CONTOUR)
    N334(FEATURE PROFILE)
    N335G90X-3.8683Y-.787
    N336G01Z-.015F15.
    N337Y.6855
    N338X-3.8411Y.6999
    N339G03X-3.7937Y.6699I.6676J1.0049
    N340G03X-3.7427Y.6421I.3603J.6012
    N341G03X-3.6818Y.6175I.1999J.4066
    N342G03X-3.6183Y.604I.0972J.3014
    Marc
  2. #22
    Feb 2012
    Quote Originally Posted by mbam View Post
    If you are truly running the exact same code on two different machines and one runs it and the other does not, then logically you can't say it's bad code. It's just that your bridgeport/camsoft machine doesn't like it.
    Again, I have seen these issues on and off over the years. Unfortunately they don't always resolve. I've actually seen motion hardware be ultimately identified as the root cause for interpolation errors of this sort.
    Try XYR arcs as a last resort. I've also seen a linear shift in coordinate system resolve this type of problem. also try changing the arc radii by a few thousands. I've seen that work also.
  3. #23
    Apr 2003
    332
    The math isn't perfect but we can get it to run here too.
    It appears that this is going to take deeper investigation. Please contact us with either your company name or serial number and the version number you're using. We will also need a current backup of your CBK file send to:
    [email protected]
    Tech Support
    CamSoft Corp.
    [email protected]
    PH 951-674-8100
    Fax 951-674-3110
    PC Based CNC Control For The Machine Tool CNC Retrofit And CNC Controller OEM Market
  4. #24
    Oct 2003
    128
    Turns out it was a problem with my CBK.
    I still don't know exactly what it was but I started from scratch with a default CBK and copied over the .fil sections one by one.
    Marc
  5. #25
    Aug 2015
    Re: Camsoft & Bobcad - problem with arcs
    im making a fixture for some parts im making and the program simulates fine but when i put it on the prototrak mill itll cut the first cut depth using side roughing then on the second cut depth it stops and says the math is bad and cant find arc centers. ive been working on this problem all day.
  6. #26
    Mar 2004
    1543
    Are you using a Prototrack control?
Page 2 of 2 12
  1. Bobcad V24 & Camsoft & arcs
    By mbam in forum BobCad-Cam
    Last Post: 09-01-2012, 12:15 AM
  2. Problem with Arcs
    By mrcodewiz in forum Dolphin CAD/CAM
    Last Post: 04-10-2012, 11:25 AM
  3. Camsoft and Bobcad ???
    By nelZ in forum CamSoft Products
    Last Post: 01-21-2011, 04:39 PM
  4. Problem with turning arcs in Flashcut
    By mjsaad in forum Dolphin CAD/CAM
    Last Post: 09-03-2010, 01:41 PM
  5. Autocad to Mach3 problem with arcs
    By LTP in forum Mach Lathe
    Last Post: 07-25-2010, 03:08 PM
