586,052 active members*
4,044 visitors online*
Results 1 to 5 of 5
    Aug 2008
    6
    Stereolithography(SLA) Printer using High Speed Galvo
    Hello Everybody,
    I made a machine for Rapid Prototyping, 3d Printer stereolithogrphy.
    have a look at it..
    please check working video of the machine.
    [ame=http://www.youtube.com/watch?v=-Vu_agjDWKg]3D Printer India, SLA (Stereolithography) , Jewellary Rapid Prototyping - YouTube[/ame]
    Photographs of jewellary parts produced by machine:
    https://picasaweb.google.com/1002574...eat=directlink
    Photographs of machine internal and external:
    Salient Feature of the machine
    Diode Pulsed Solid State Laser source Fully Computerized control.
    High speed and accuracy
    High surface quality
    Direct casting
    Master models for rubber moulds
    No lamp replacement (20000 hours of diode life)
    No calibration
    Specification of the machine:
    Technical data:
    Laser source: DPSS UV Laser 405nm
    Scanning method: High Speed Galvo mirrors
    Working area (x, y, z): 110 x 110 x 200 mm
    Slice thickness*: 0.01 – 0.10 mm
    Laser scanning speed: 0-4400 mm/sec
    Software : Canux Controller
    OS: Windows 7, WinXP
    Input file format:
    .stl - .slc, .mkr(DWSSystems format), gcode
    Machine size: 380 x 515 x 733 mm
    Weight: 50 Kg
    Operating Temperature Range: 22-25°C
    Operating Humidity Range: 60%
    Electrical consumption: 400 W
    Power supply: AC 230/115 V / 50-60 Hz
    Standard accessories supplied with our machine:
    No. 1 Building platform mm 120x120 (working area: mm 110x110)
    No. 1 Resin tank.
    No. 1 Set of handling tools
    No. 1 Personal Computer with Touch Screen monitor(Built in machine)
    No. 1 UPS 650VA 230V 50/60 Hz
    No. 1 Canux Controller Software License
    No. 1 MeshLib open source Software for STL Processing
    Mesh Repair (module P02)
    No. 1 User manual
    if any question please mail me back..
    thanks,
    Himanshu Bhatt
    Mar 2009
    5
    3d printer
    Hi,do you sell this printer ?
    Mar 2009
    5
    Hi,do you sell this printer?
    Aug 2008
    6
    Yes we sell this machine. but mind well this is not DIY machine. all laser parts are from Scanlab.de (Germany). We can make cheap machines too
    Mar 2009
    5
    Ok,I understand, but you sell like a kit o full assembled. pls give me a price of both,thanks
  1. Stereolithography file to GCode
    By rweatherly in forum Coding
    Last Post: 03-22-2018, 04:05 AM
  2. High speed spindle... how high?
    By jonesja2 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2015, 04:37 PM
  3. high speed machining (High RPM)
    By bucketbot in forum MetalWork Discussion
    Last Post: 06-14-2012, 09:34 AM
  4. New High Resolution printer being crowd-sourced...
    By mcphill in forum 3D Printer / 3D Scanner Discussion
    Last Post: 04-02-2012, 09:16 PM
  5. High Precision, High Speed Bearings
    By mikeyg in forum News Announcements
    Last Post: 09-08-2009, 01:06 AM
