CNC plasma and flame cutter for sell
Technique Features:
Model LHBX-3
Control system Start-2012AH
Drive motor Stepper
Plasma Torch height controller Automatic
Effective Cutting Width (X axis) 1.5m
Effective Cutting Length (Y axis) 2.5m
Plasma Power Hyperthermia Powermax 45A
Plasma Cutting Thickness 1-10mm
Plasma cutting material Stainless steel,copper,aluminum and so on
Drive Mode Single-side
Cutting Speed 0-3500mm/min
Moving Precision 0.01mm/step
Power Source 220V 50Hz 1000W
Plasma Gas Pressed air, Oxygen, N2
Power supply AC 220V/380V 50/60Hz 1000W
The machine size 1.75m*3.0m
Application:
It can cut mild steel and high carbon steel, stainless steel, aluminum, copper and other non-ferrous metal (plasma cutting), etc, be widely applied in industries such as machinery, automobile, shipbuilding, petro-chemical, war industry, metallurgy, aerospace, boiler and pressure vessel, locomotive etc.
Features:
1. Telescopic arm type. The unique design, compact structure makes it take up small place, stable operation, and high cutting precision. Chassis and cantilever are aluminum materials, smart, light weight, mobile convenience.
2. The model is equipped with plasma cutting torch and Plasma interface. It is a high efficiency, energy conservation cutting equipment; also it is profiling cutting machine and the upgrades of general portable CNC cutting machine.
3. with arc voltage automatic increase equipments. Move as a whole, used as "small car" can be placed directly on the cutting plate, easy to operate and flexible
4. The control system is the latest Start-2012AH, and 7inch color LCD screen.
5. IBE Simple nesting software, to make the maximum use of the material and reduce the cost.
6. The guide rail can be thickening and lengthened according to the customer.
7. The Plasma Power is U.S hyperthermia air plasma power PowerMax45A (made in U.S).
