586,119 active members*
3,454 visitors online*
    Apr 2006
    97
    views on the st20 please
    been looking at a 12mth old st20 with bar feed just wanted to know if they are any good or should i stay clear thanks
    Nov 2006
    490
    They're pretty stout machines compared to the previous SL-series lathes. Though as always it will depend on what you're doing with it....
    Apr 2006
    97
    Smile
    thanks would not be doing anything to demanding justmed to lge batch work nothing bigger than 2in or 50.8mm dia .
    would only be doing mild steel and alu components to tolerences or + - .001in or .025mm
    the one i have been looking at has a barfeed with it which is what we want for the longer running jobs .
  1. Haas ST20 Lathe Tool Offsets
    By Wod in forum Haas Mills
    Last Post: 02-07-2012, 06:12 AM
  2. ST20 drills off offcenter
    By BryanDavid in forum Haas Lathes
    Last Post: 09-26-2011, 08:47 PM
  3. Mazak ST20 ATC M/C Drilling Operations
    By diesel_dan in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-06-2011, 02:33 PM
  4. new ST20 any opinions??
    By gixxergary in forum Haas Lathes
    Last Post: 05-11-2011, 09:10 PM
  5. Solidworks views
    By Cammotion in forum Solidworks
    Last Post: 05-01-2007, 02:35 AM
