586,111 active members*
3,215 visitors online*
    Oct 2005
    7
    Question diferent type flywheel
    hello all,
    i'm curious? would a fly wheel shaped in an eliptical shape work?
    i'm building low temp stirling engins for show. thought i might be fun to make a strange looking flywheel. wouldlike to try one shaped from an elipitical program.
    any thoughton this working or being a problem child ?
    larry in alaska
    May 2004
    4519
    As long as it is well balanced, should be no big deal. It would not be as efficient as a fully round flywheel though. Do you understand the physics of a flywheel?
    Apr 2010
    294
    Any shape you like can work in theory - as long as you pivot at the point of balance.
    Low temp Stirling engines can be quite fussy - as they produce so little power you need everything in your favour - particularly the little ones that run on the palm of your hand. You might find that a stray draught may disturb an odd shaped flywheel more than a disc one. Perhpas that's also why discs seem to be preferred on this type over spoked - less aero drag. If you're going for a big one (1 foot diameter displacer), you may be less affected.
  1. 10K RPM Steel Flywheel Build
    By magudaman in forum MetalWork Discussion
    Last Post: 05-29-2012, 10:48 PM
  2. Forced Flywheel
    By nolage in forum Benchtop Machines
    Last Post: 03-13-2012, 05:48 PM
  3. SAVING IN DIFERENT FORMAT
    By littlebrewman in forum Mastercam
    Last Post: 04-15-2010, 05:11 AM
  4. Flywheel rpm & energy storage math?
    By DennisCNC in forum Mechanical Calculations/Engineering Design
    Last Post: 08-20-2008, 06:47 PM
  5. wanted g code for flywheel
    By propclock in forum G-Code Programing
    Last Post: 03-24-2007, 05:01 PM
