586,111 active members*
3,146 visitors online*
    May 2009
    1332
    G540 / Mach3 E-stop
    This is my first experience with G540. I have 4 motors connected and on power up I got the green light and all works fine so far
    But I don’t understand the E-stop. I have connected in pos 10 my E-stop switch and when I press it, G540 light goes red but Mach3 doesn’t see anything wrong; then G540 turns off and then Mach3 sees the problem and asks for reset.
    Is this normal? and which pin in Mach3 should the E-stop be assigned?
    Nicolas
    Apr 2010
    294
    Gecko manual says pin 15
    May 2009
    1332
    Good to know, thanks
    Nicolas
    24221
    You can assign as you wish, Configure ---Ports & Pins screen.
    Al.
    Albert E.
  1. G540 and E-Stop
    By dpgoldberg in forum Gecko Drives
    Last Post: 05-11-2018, 08:17 PM
  2. G540 E-Stop
    By kolias in forum CNC Machine Related Electronics
    Last Post: 12-19-2012, 05:33 PM
  3. G540 E-stop and Mach3
    By Astroguy in forum Gecko Drives
    Last Post: 02-03-2012, 05:10 AM
  4. G540 e-stop question
    By vintageracer in forum Gecko Drives
    Last Post: 01-04-2010, 11:45 PM
  5. G540 Low voltage for E-stop and limits?
    By MrWild in forum Gecko Drives
    Last Post: 10-14-2008, 10:28 AM
