586,406 active members*
3,098 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Helical output for spiral leadin on 3d toolpath.
Results 1 to 8 of 8
    Feb 2010
    71
    Hi Guys,
    Is there any way to get Bobcad V25 to output a helical toolpath on leadin instead of line segments on 3d toolpaths. I know I saw SBC's post on scripting somewhere here but I'll be darned if I can find it. Any help or ideas to reduce to amount of code on these toolpaths would be appreciated.
    Doug
    Mar 2012
    1570
    Check the posting tab for your 3d tool paths. It has an option for line or arc output. I don t think it works for the lead in, but the rest of the movements where an arc fits it will be posted as one.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Feb 2010
    71
    Hi Al,
    I see an arc fit tolerance, that I am using. I guess what I am looking for though is how much tolerance does it take.
    Doug
    Mar 2012
    1570
    What tool path are you using? The defualt settings should work just fine...
    Al DePoalo
    Feb 2010
    71
    Using Z level rough and finish.
    I have attached the file I was working with.
    Attached Files Attached Files
    Mar 2012
    1570
    If you are using the Mill Pro package I would drill a hole for your roughing end mills to start in. This way you won't need to helix or ramp down in order to get in the cut.
    Using ADV Rough you have the option to pick a drill tip position. The reason why it's called a drill tip position is simple. The point you pick would be for the hole your drilled, and how deep in Z it went.
    free image hosting
    Using this option your 3D rough path with start in the drilled hole and eliminate the need to ramp the tool into the part.
    Do you have an older controller?
    17476 lines of code with arc fit off
    7517 lines of code with arc fit on
    photo hosting
    Al DePoalo
    Feb 2010
    71
    I am running an older control and using mill pro. Thank you for your suggestions and I will give them a try.
    Mar 2012
    1570
    Z Level Rough with ramp option using arc fit = 1231 lines of code
    ADV Rough using drill tip and arc fit = 190 Lines of code
    That is a huge about of code savings!!!!!!
    You asked about your arc fit tolerance. The default is .0005 But because your machining tolerance you are using for this part is .001 I matched these values
    It took your Z level finish from 540+ lines of code down to 380+ lines of code. So that will save you a little bit as well.
    Anyway I hope that helps.
    Al DePoalo
  1. parametric program for spiral helical interpolation
    By Bastida in forum Parametric Programing
    Last Post: 12-31-2011, 02:59 AM
  2. helical spiral interpolation
    By dry run in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-09-2011, 10:45 AM
  3. spiral helical interpolation for HEIDENHAIN
    By Bastida in forum CNC Machining Centers
    Last Post: 05-23-2010, 12:50 PM
  4. Helical Interoplation (Spiral Cut)
    By kjm30 in forum G-Code Programing
    Last Post: 02-02-2010, 03:29 AM
  5. Helical Ramp Toolpath
    By steve@boroUK in forum BobCad-Cam
    Last Post: 10-21-2009, 01:48 PM
