586,119 active members*
3,512 visitors online*
Results 1 to 12 of 12
    Oct 2009
    24
    EMCO COmpact 6
    Hi All Emco 120 owners
    I just bought a EMCO compact 6, my problem is that it came with out tool holders, and I can't finde a dealer that sells them.
    any one know where to bye them ? Item no. A7R 000 880 and A7R 000 870
    perhaps some one have the drawings so I can make them my self.
    It have to be metric.
    Regards Mike
    Oct 2009
    24
    I forgot ! all loves pictures so here are one of my new machine
    Jul 2010
    EMCO compact6 tool holders
    I also just bought a EMCO turn 120 lathe that I plan to retrofit to LinuxCNC,
    it came with one 2.5mm drill bit collet.
    So I will also have to make some more as well.
    The clamped cutout has a slight taper to it such that the collet gets stuck in the tool turret.
    For the turning tools, I don't know how they are supposed to mount in the tool turret. Maybe wedge a small bolt and nut in the slot between the tool and turret? will have to find out.
    Oct 2009
    24
    Hi Bad_G
    Thanks for the drawing, i need that too. I also need drawings of the clamp.
    Like I said, there is nothing left only the turret, all tools and holders was removed.
    /Mike
    Jul 2010
    Tool Clamp
    Yes same with mine, just had that one collet.
    If someone could please post a picture of the Outer Diameter Tool Clamp, so I can replicate it.
    Oct 2009
    24
    I have now tryed to contact CNC_SWE on PM bud no response, I can see that he have made the tool holder for his EMCO 120. Is he still around on this forum ? or if CNC_SWE read this please contact me.
    Jul 2010
    Hi mikeDX,
    I also found that thread by CNC_SWE, http://www.cnczone.com/forums/emco_l...volver_pc.html
    I drew it out using the dimensions off my tool turret.
    It seems to me that there are just two M6 bolts that do the clamping.
    I'm going to use Glanze 12x12mm indexable turning tools,
    This is what I'm going to machine for mine.
    Oct 2009
    24
    I can see I have a different turret than yours, my is the new model, but the Clamping gib is the same, I have 2 of those. If you send me the DXF of the clamp I will put in the right measure. It is 6mm bolts but with 8mm heads. see pic.
    I have contactet EMCO for buying A tool holder, waiting for reply.
    /Mike
    Jul 2010
    It's a 6mm bolt with a 10mm head.
    Oct 2009
    24
    Okay, but the one I have here it's 8mm head, I think it's easier to get your tool in to tightening the bolts with a 8mm spanner instead of 10mm. spanner
    No news yet about the tool holder... I didnt think it would be that hard to get one.
    /Mike
    Dec 2009
    14
    Are you still looking for drawings?
    I made some years ago of my own.
    Do I seek the drawing?
    Jun 2011
    6
    Re: EMCO COmpact 6
    Hi
    Just to end this Thread, I made the tool holder my self and I love to share it with other with the same problem.
    This tool holder fit the new turret.
    /Mike
    Attached Files Attached Files
  1. help! emco compact 8, should I buy it? cnc-able?
    By acannell in forum EMCO Lathe
    Last Post: 11-11-2013, 07:38 PM
  2. emco compact 6
    By fketchum in forum EMCO Lathe
    Last Post: 03-29-2012, 07:39 PM
  3. EMCO Compact 5PC
    By Robin Ringwood in forum EMCO Lathe
    Last Post: 10-09-2011, 09:16 PM
  4. EMCO Compact 5
    By helfriwj in forum Mini Lathe
    Last Post: 04-11-2008, 02:33 AM
  5. EMCO compact 5 PC to win XP?
    By SBruceSmith in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-29-2006, 08:30 PM
