If the back of the Z column is already deformed from having the Nut torqued down too much, then a even a heavy duty washer will just deform until it meets the surface of the column.
You would need a belville or dock washer, they are much much thicker and designed for distributing very high loads all the way out to the edge of the washer, giving you more surface area between the nut and the column.
