Below is a link to an enhanced Mach3 Mill screen. It is very similar to the original Mill screen, but as I do not like to switch the screens a lot, most of the functions are now on the main screen - MDI etc (other screens are still retained with enhancements). The screen will allow you to switch between the jog modes, without any tabbing. Also supported is the MPG mode. When selected you can either use velocity setting, or multi step modes: coarse (0.001" step), or fine (0.0001" step). You can also touch Z, or set your XY zeros directly. This screen has been customized for my pendant, but those are added hotkeys for the off-screen buttons. I have retained the same shortcuts for the on screen stuff, so it will work for everyone.
To install:
Unzip the file somewhere. Copy the 1024.set to the main Mach3 directory (it will overwrite the existing file so you may want to rename the original file). Copy the MillBitmaps to the Bitmaps folder (this will add additional pictures for the screen controls). Same with the macros.
The main screen picture can be seen at:
www.novalab.org/mc/ScreenShot_MILL.jpg
Download from:
http://www.novalab.org/mc/Mill_Screen-C.zip
NOTE: use save as option, as this board will not allow direct forwarding.
I also have a new Turn screen, with only one screen, and will release it when the testing is ready.
Let me know of any bugs, or your feedback.
Regards
Chris
