Hi, I want to build my first cnc machine around some plans I found over the internet and want to design a cnc with about 32"x23"x"5" cutting area, so the idea is to make a large cutting area for my hobby projects and to be able to cut hardwood, acrylic, MDF, thin copper sheet with no problems with a decent speed. I will make the cnc structure out of MDF...the only problem now is that I'm on a low budget, but first, I try to find a good combination, cheap and strong of a -3 axis kit-. I found some options, and I want to show you before I buy them - what would be the best choice:
1. CNC Router kits 3Axis Nema 23 Stepper Motor 425oz-in,3.0A Dual Shaft Wantai CNC Mill Control - costs 310 $ (including shipping) -> (a problem I see with these chinese products after reading some posts is that the driver can break quickly or the stepper motors are not as powerful as they say - my only fear is not loosing my money if I get bad products )
2. HobbyCNC PRO Driver Board Packages - 3 axis w/(3) 305 oz.in - 4,2V 3A Steppers - costs 355 $ (including shipping)
3. 3-Axis NEMA23 CNC Kit (36V/9.7A/270 oz-in/KL-4030) - costs 410 $ -> (or the 425oz version + 50 $ more)-expensive though :P
4. 3 axis CNC driver Bipolar + 3 x 1.9Nm(269oz.in)Stepper motors - cost 250 $ (with the 269oz.in steppers)-> (or 425oz.in - 15$ more for each)
Driver Specs:
3-axis driver control - 3 stepper motors with a maximum current of 3.5 A per phase
The driver is bipolar and can be connected stepper motors with 4, 6 and 8 wires.
Over sized radiator cooling, done very efficiently in most cases do not require ventilation.
LPT parallel port connector direction and step pulse step / dir so it is compatible with most software for numerical control, Mach3, Turbo Kcam CNC, EMC etc.
3A peak current 3.5 A maximum continuous
Power supply 30V maximum recommended single source 24v
Micro steps 1/1, 1/2, 1/8, 1/16
PWM current adjustment in 4 steps.
Relay 10A cutter control of software
3 Position Control Selectable induced current.
Overheating protection,
5. 4 Axis Bipolar Microstep Stepper Motor Driver CNC4X35A + same stepper motors versions as previous - costs 315 $ (with 269oz.in motors)
That's all I could find more reasonable on price/performance...or I could try to make DIY drivers, controller and power supply to be more cheaper, but I would encounter a lot of problems and maybe slow performance on them, so I think I remain on these 5 options, unless you could give me better ones.
What would be the best option on price/performance you recommend for what I want to achieve ? Please help !
Sorry for the bad english
Thanks in advance
