586,655 active members*
4,064 visitors online*
Page 1 of 4 123
Results 1 to 20 of 64
    Nov 2009
    4415
    G0704 BD Tools build pics
    There are quite a few threads here on transforming the 0704. I am posting pictures of my build due to the ease of the iphone. Documentation is minimal and if you have questions or pictures please contribute.
    My build consists of BD Tools mounts and Linear Motion 2008 screws. I have made a change or 2 here and there.
    If you see something noteworthy, ask and I will tell you all that I know.
    Nov 2009
    4415
ID:	167066Click image for larger version.
ID:	167067Click image for larger version.
ID:	167068Click image for larger version.
    This last picture shows the orientation of the nut originally. I turned the ball nut around and installed it in the other side if the Y bracket too. I machined it down for an offset and gained a total of 8.4" in Y.
    A lazy man does it twice.
    Nov 2009
    4415
ID:	167070Click image for larger version.
ID:	167071Click image for larger version.
ID:	167072Click image for larger version.
    Nov 2009
    4415
ID:	167074Click image for larger version.
ID:	167075Click image for larger version.
ID:	167076Click image for larger version.
ID:	167077Click image for larger version.
ID:	167078Click image for larger version.
    Nov 2009
    4415
    So I flipped the Y axis bracket around and milled the semi circular part off to allow more rearward travel. This mod alone gained about .7" useable. Well worth my time.
ID:	167083Click image for larger version.
ID:	167084Click image for larger version.
ID:	167085Click image for larger version.
ID:	167086Click image for larger version.
    Nov 2009
    4415
    Some of those other pics were blurry. I did have to grind the top of the flange to allow the mount to fit flush with the table. It all worked very well. A small 1 to 1 1/2" spacer between the column and base just like Hoss' but likely thinner.
ID:	167088Click image for larger version.
ID:	167089Click image for larger version.
    Nov 2009
    4415
    Just running a warm up wizard at 100 ipm.
    [ame]http://www.youtube.com/watch?v=nbY9n8GIzm0&feature=youtube_gdata_player[/ame]
    Nov 2009
    4415
    A view from different angles underneath while running a warm up wizard.
    [ame="http://www.youtube.com/watch?v=rxc--tVlCrM"]G0704 from underneath - YouTube[/ame]
    Good stuff, keep it coming.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Nov 2009
    4415
    Wouldn't have been possible without you and people like you. If I can get anywhere close to your creativity I would be delighted. Thanks
    Nov 2009
    4415
    All axis assembled and warming up.
    [ame="http://www.youtube.com/watch?v=GrIrHZbY2To&feature=youtube_gdata_player"]More G0704 fun - YouTube[/ame]
    Nov 2007
    980
    Nice pics and video, thanks for sharing as I'll "someday" CNC mine as well.
    May I ask what couplers you're using (source?)?
    Thanks again-
    Dave
    Dave->..
    Nov 2009
    4415
    I thought they came from MSC. I will have to check.
    Nov 2009
    4415
    I was trying to measure backlash here in this video. My X and Y had about this same amount, I am guessing in the .00025 range. That indicator is a .0005 scale. I measure almost .001 in Z, all of that is without backlash compensation enabled.
    [ame="http://www.youtube.com/watch?v=f4MGsc1979A&feature=youtube_gdata_player"]G0704 BD Tools measuring for backlash - YouTube[/ame]
    Nov 2009
    4415
    Just cutting a simple 1.75" diameter pocket in wood at 120ipm @ .1 doc @5% step over. No issues whatsoever and the hole was round. I couldn't detect any bumps or irregularities on the inside of the hole.
    [ame="http://www.youtube.com/watch?v=Q7EXkaIsISs&feature=youtube_gdata_player"]G0704 pocketing in wood at 120 ipm - YouTube[/ame]
    Feb 2012
    296
    Great pics and vids!
    Do you mind explaining a little more about what you did with the y-axis and spacer?
    I have the BD Tools mounts and linearmotions2008 screws myself and I am looking to finish up my conversion within the next couple weeks.
    Thanks!
    Nov 2009
    4415
    Quote Originally Posted by DRock View Post
    Thanks!
    Sure, First of all I did enlarge the opening in the center of the base. I didnt do it as much as Hoss did in length. If and when I recut it, I will leave only 1/2" at the back (where the bottom of the Z column rests). With a spacer this should give a little more over travel than I am getting now.
    The Y mount provided by BD Tools has a semicircular side cut to allow the ball screws flange to sit flush. I milled the circular part off and mounted the flange on the other side of that mount. I could actually gain a bit more coming forward as the table will come all the way forward til it hits the round tube where the couplers are. This round tube stands proud of the bearing block just enough to hit the carriage. You could mill or flycut the top of the tube or cut clearance in the bottom of the carriage. I would choose the first option.
    Nov 2009
    4415
ID:	167256Click image for larger version.
    These pics show where I opened up the middle. I actually cut more than this eventually but forgot to get a pic. I will pull it apart again soon to cut it up some more.
ID:	167258Click image for larger version.
    This is the ball but mount I modified. I did have to grind the flange of the ball nut a small amount to allow the mount to fit flush with the top of the carriage.
    Nov 2009
    4415
    Once you take your mill apart to do the conversion it will be apparent how this is working. It might be a little confusing til then.
    Nov 2009
    4415
    This is what I meant by the limiting factor in the front. I believe Hoss' stepper mounts allow much more over travel off of the front than Billy's.
Page 1 of 4 123
  1. 109JB's G0704 conversion (pics now, plans soon)
    By 109jb in forum Benchtop Machines
    Last Post: 12-30-2020, 09:51 PM
  2. cnc router build ( pics )
    By katran in forum CNC Wood Router Project Log
    Last Post: 10-26-2016, 03:56 PM
  3. My SX2 CNC build! (lots of pics)
    By asifjahmed in forum Benchtop Machines
    Last Post: 04-15-2016, 06:31 AM
  4. Grizzly G0704 vs. Quality Machine Tools/Precision Matthews PM-25MV
    By automatafan in forum Benchtop Machines
    Last Post: 10-13-2013, 05:38 PM
  5. g0704 and tools all finally here
    By Whizbang in forum Benchtop Machines
    Last Post: 12-15-2012, 10:27 PM
